teleburst,
If you can't get this to work after one more try, then use the one-click app:
http://androidforums.com/all-things...is-app-apk-no-pcs-no-scripts-needed-easy.html
The instructions there are not as verbose as in this thread, but there are fewer steps to be performed by the end user (and thereby fewer places for a mistake to creep in).
Make sure to follow the instructions about backing up your current ROM using Nandroid (3rd or 4th post in this thread) as the first thing you do after getting Amon_RA up and running. (That app installs the same recovery boot as this method).
Good Luck
eu1
Good Luck
eu1
