After running root_part2
I am getting no space to write after the Installing tools message in gscript, but there is 4GB available on the phone
and then it wont boot into the Amon_RA recovery mode via vol+ or vol- and then vol+ method, just the normal HBOOT mode.
Please help
Please help
I figured it out... apparently there must have been some conflict with the Astro File Manager and apps backup file I had made. Because I deleted that and the script ran perfectly after that. Odd?
eu1,
Was I on the right track? Don't want to steer anyone the wrong way...
Thanks.
Does this also work for the 2.1 OTA Updated Eris's? Sorry i'm new to android software but am familiar with Jailbreaking iphones. I'm not sure what the different roms are though... Is there a fairly popular one that most people use?
Thanks in advance
The process was great!!!! My phone rooted beautifully... BUT now when I try to reload the DROID X keyboard (the black keyboard) - I can't. I intalled the APK for the DROID X, when to type a text and "long press", but I get nothing..
What may be the problem??
Thx
Cynthia
Cynthia,
I think you've got to go into Settings -> Language & keyboard -> Input method and select "Multi-touch keyboard". Did you do this already?
Excellent - thx much!! that did it.. I missed that part..![]()
***( A number of people have reported that the Vol-Up + End/Power key combination does not boot the custom recovery, but instead just boots the normal phone O/S. If this happens to you, instead, use Vol-Down + End/Power to boot into HBOOT mode, and then press Vol-Up to start the Amon_RA Recovery )
Any suggestions for when neither works?
The boot problem is more stubborn; yes, I've been very careful to press and hold the two buttons through the power up. Usual OS comes up.
vol-down + end just results in the phone vibrating to tell me the volume is down and displaying the "shut phone off?" screen. I've powered it down dozens of times.
Just out of curiosity, what was the maximum speed you had set up when your phone was "restarting"?
An OS crash like that is very symptomatic of using too high a clock speed, and that maximum clock speed value varies from phone to phone. (It is also statistical in nature - meaning that if you use an extremely high value, your phone will crash immediately, but if you back off the max speed, you might still experience crashes -just less frequently. I would say that a "safe" max frequency is one in which your phone never spontaneously reboots in a week or more of continuous service.)
Also, I think I saw some reports claiming problems (either battery life or sluggishness) by people using the SetCPU widget - the claims that they made were that using just the SetCPU app (with profiles and auto-start) solved their problems. I haven't verified such claims, but it might be something to be aware of.
eu1
Yay!!! That did it. (hboot is 1.47)
Thank you!
Im not for sure but I think that it was like 710. It started when I enabled profiles and tried to use that. I deleted the app and found one called Overclock Widget and I have it set to 768 and have no problems what so ever. Granted it isnt as detailed as SetCPU but it has a screen off setting and one for on, just not for battery monitor. Maybe it just doesnt like my Eris... lol
On another topic, is the procedure for flashing another ROM (curr using PJT2v2) the same as when I put this one on here. I used the GScript Lite tut to do it. I know that I dont have to rerun GScript just do the wipe and flash. I guess my question is is there anything else that I have to do when flashing a new ROM?
Also, in your great and humble opinion, what would you recommend for a ROM? There are so many choices and methods I get lost in all the commotion. Any advice would be greatly appreciated. Thanks
Um...new problem. I'm at the "flash zip from sd" and it's coming up "E:no zip files found". It's there -- or, it was. I downloaded plainjane from your link above. what now? (and, sorry)
Can I reboot and start over? is that gonna kill the phone? Can I connect it to the computer and have a look at the sd card? Can I power it down and recharge? (it's gonna need it soon). Eeep.
