ok first off amazing instructions but of course with my luck something went wrong...all was well and went perfect until figure 40 were you select your rom...i selected it but im pretty sure it said it failed but before i caught that i rebooted...so im back on my phone and everything is working but i dont think the rom is installed i think its just the factory settings and os. So my question is how do i make sure im rooted or where do i start from to try and reinstall the rom? Id imagine i have to re download t
he rom and then start from where? thanks for any help !!
i started reading a little more and if i am rooted (pretty sure i am but would like to know how to check) can i just start at the finishing up thread and try to reinstall the rom from there? thanks.
gonefishin96,
Normally when you flash a ROM from a .zip file on the SD card, a verification step occurs where the (Amon_RA) recovery boot first unpacks the entire zip file, and one by one computes a SHA1 checksum for every file in the .zip. It then compares those computed checksums to checksums in the manifest file . If those all match, then it checks the signing that was performed on the manifest file. If all those steps succeed, it then continues and actually begins "flashing" the files from the ROM .zip file to system memory.
For all those checks to succeed, it is simply not possible for the .zip file to be corrupted in any way. That is not to say that an error could not occur - the most likely one is that the battery charge was a little too low, and a write failure occurred. (The .zip file is OK, but something happened when
writing everything from the .zip file to system flash memory.
Now, the "wipe" operation destroys the /data and /cache partitions. And usually, the first thing that happens during a ROM install is that the /system partition is "formatted" (Actually, it is just erased, but we'll call that "formating").
So, if the ROM install somehow failed very early - then you still have the old ROM on there, but in a state very similar to a factory reset. If the ROM install failed later, then you would have *part* of the ROM installed but not all of it. Usually (but not always) the ROM dev makes an effort to change the splash screen during boot with something nifty. If you saw the "standard" splash screens during boot, you probably just have a "factory reset" version of a stock ROM. You can verify this by going to
Settings -> About phone -> Software Information
You can check
this post to see if what you see in your phone matches a "stock" HTC ROM.
If it does, then I'm guessing you somehow corrupted your ROM file when you downloaded it. The typical way this happens is by: (a) and interrupted download, or (2) improperly disconnecting the USB-mounted SD card.
If you copied the ROM file from your PC to the phone, you need to perform a "Remove Hardware Safely" operation on the PC (after you have finished copying the ROM to the E:, F:, G: or whatever drive the SD card is mounted at) - and then when the little balloon pops up saying something like "Safe to remove hardware", then you can turn off Disk Drive Mode on the Eris. (Or toggle off "USB-MS toggle" when using Amon_RA recovery).
If I were you, I would download the ROM again to the PC. When finished, use Windows Explorer to find the file and Right Click -> Properties. Write down the EXACT number of bytes in the file (on the PC). After you have copied it to the Eris, use a File Manager on the Eris to check the same number - it should be exactly the same number of bytes.**
That's the long way of saying, "yes, you can skip the initial steps, and proceed right to the "Wipe data/factory reset" followed by flashing the new ROM from the SD.
eu1
** If you want some practice using Amon_RA and Nandroid, before this step you may (optionally) start up Amon_RA and perform a Nandroid Recovery of the backup you previously made - if you want to prove to yourself that you can get back to exactly where you started.
PS Please charge your phone very well before you ever flash a ROM or perform a Nandroid Recovery. 100% charge is a pretty safe number to use.
