I'm afraid I'm stuck in a bootloop... followed the instructions, everything went swimmingly, flashed kaosfroyo 3.1, and now the screen is black with "android" in white and a sort of light scrolling by behind the letters (if that makes sense) for the past 40 minutes. I'm thinking I'll just go to bed and see what it looks like in the AM - but wondering what is the next step, assuming it's still stuck? Battery pull presumably, but then what?
thanks in advance, and g'night all...
(KaosFroyo V31, not v3.1, right?)
95 out of 100 bootloops seem to always be due a short list of things:
1) Failure to perform a "Wipe data/factory reset" immediately prior to flashing a new ROM file (from the SD card), or
2) A problem with the SD card of some sort, or
3) There was actually an error thrown during flashing and the person doing the flashing didn't take notice of it.
You can try doing either of these two alternatives; in both cases, please charge your phone up very well (100% is a good number!) before you begin:
(1)
- Reboot into the (Amon_RA v1.6.2) recovery, and:
- Wipe data/factory reset
- Flash the same ROM again
- Power the phone off
- Eject the SD card before you...
- ...power the phone back on
This first method eliminates the first two most common causes of bootloops; also, note that you should not need to wait 40 minutes. If your phone has not booted completely within 10 minutes, it is in a bootloop. If it boots successfully, go through an initial configuration of your phone, and then insert the SD card to see if it gets recognized.
(2)
- Restore the Nandroid backup that you made.
- Reboot.
You did make a Nandroid backup, right?. This 2nd alternative allows you to use the phone OS and configuration that you are familiar with to download a different ROM (or re-try downloading/copying the same ROM), and proves to you that all is not lost - you can always get back to where you were if you have good backups (in a safe place).
eu1
