JusJazzyMonroe
Thanks to GREAT AND CLEAN instructions, I have successfully rooted my phone. BUT, I am unable to receive any MMS messages...
Am I alone?
Am I alone?
Am I alone?
I was able to root my Eris, and install V32. All is great! It is faster. Re-installing Apps andthey came in great. Now just one more item. Is V32 suppose to allow me to initiate phone calls from my bluetooth without hands on the phone? This is not working. If I press the button on my Bluetooth I see the Voice Dialer start up, but I hear nothing in the earpiece and it fails. Is there a way to get this to work? Am I the only one with this problem?
Thank you for the reply and advice. Is there a way to contact the XDA developer for Kaos and get their advice on this? I would like to know if they are aware that the bluetooth is not supported and to find out if they have fixed it, which version or when do they plan to do so? I am totally happy with V32, except I was hoping the Bluetooth would be supported.
I see now there is a V34. But again, they do not mention the bluetooth issue.
Kaos regularly answers questions in this thread on XDA, you could ask there. [ROM]KaosFroyo V34 [09/08] [FROYO] - xda-developers
One person reports the Bluetooth works in V30. I was on 2.1 and now upgraded to V32. What will I lose if I go back to V30?
I am a total tech noob... read lots of posts on many pages ( holy crap 12 of them) and one question I can't seem to understand is in layman's terms... Is it reversible back to factory 2.1 ota? Thinking about off loading on Ebay to subsidize a new droid if this doesn't help with issues. Thanx in advance![]()
Yes, you can revert to stock. There is a thread on the XDA forums called "Eris back to stock". I would link it, but it looks like they are having server issues, lol.
You should be able to Google "Eris back to stock" and find more info too.
IndyRoadie,
I work down in the Grove! Good to see a fellow Indy Android user! Cheers!
Oh Hi there. Ok well im looking into rooting my Eris, tired of it slowing down and stuff. Can I use this "1 click method" and then just use the new V35 Rom KaosFroyo. And thats all I will need?
Thanks. I decided just to go with xtrSENSE. Went through without a hiccup. This isn't the first time messing around with flashing stuff, Ive done alot of PSP modding a few years back. This is just the first time with a phone.MrGrimxx,
Welcome to Android Forums.
I see you've posted the same question in both this thread and in the 1-click thread. Quick answer to your question is "yes". Either method will root your phone in the same way. However, this thread has much better instructional value that you'd be well-advised in reading through and following regardless of which method you ultimately choose. In order words, you'll have many fewer follow-up questions, if you know what I mean.
Cheers!
If I were you, I'd try xtrSENSE or xtrROM first. They are 2.1 ROMs, but they use a feature called cache2cache which moves the rather large Dalvik cache out of the same storage area in internal memory where your apps are stored, leaving plenty of room for a lot of apps without having to do apps2sd.
If you are going to try a Froyo ROM, I'd suggest looking at Kaos Froyo or CELB Froyo, my two favorite Froyo ROMs. However, there is a lot more space for apps in Kaos Froyo, so that may be your best choice. Even with Froyo ROMs, I would stay away from apps2sd unless you really, really need it.
I have read that xtrSENSE has problems with rebooting. I have heard good things about Kaos, but obviously I dont want to royally mess up my phone so I'm just looking for the basic to install onto my SD card. Please advise.
