ErisOwner017
This posting is amazing! +10000 to erisuser1 for putting this up and making me a new root user!
i've done everything correctly but after i flashed the plain jane rom, and everything goes smooth but then i'm having boot loops like the ERIS screen will come up then the Plain Jane on top of it will appear then it will just repeat itself...
what is wrong?
nyccharlie,
I will answer your question - reluctantly, but first, yet another cranky complaint from eu1: your question is off-topic, and would be better placed in either a more relevant thread, or a new topic that you start. Don't be afraid to start your own threads - just make sure to give them a title which relates to the question you are asking.
Yes and no.
If you try it the way you describe it, no. The reason for that is that the baked-in goodness/badness of apps2sd starts during the booting process - so you need things inside the boot partition to make it all hang together correctly so it will start correctly from boot-up.
Also, you will need to carefully review the script to make sure that all the dependencies it needs are satisfied - my bet is that may require a version of busybox to be installed on the phone, too.
It is possible, however to preserve your existing OS and slip in a different boot image right underneath it. You might want to do this anyway, as it would give you an opportunity to use a new kernel with overclocking (The kernel is part of the "boot.img" file). Just make sure that you use an Android 2.1 ROM for the source of your apps2sd/a2sd scripts and "boot.img"
If you try this, make absolutely sure that you create good Nandroid backups before you begin. What I would recommend is that you use a2sd/apps2d and a boot image from the same ROM.
You can manually install a new boot image (after you make a Nandroid backup!) via adb with Amon_RA booted:
- boot Amon_RA, then:
Maybe I will put together a related post about doing similar things - in an easier way (not apps2sd specific, though)Code:adb shell mount /sdcard adb push boot.img /sdcard/new_boot.img adb shell md5sum /sdcard/new_boot.img ( do not proceed if the MD5 signature is not valid ) adb shell flash_image boot /sdcard/new_boot.img adb shell rm /sdcard/new_boot.img adb shell umount /sdcard
eu1
 might have to learn using a vm of  ubuntu.I'm having problems transferring the zip file to my phone, when it's done transferring the size of it wouldn't be the same as the original file on my computer.
How do i fix??
Ok, so after reading numerous posts and articles on rooting, kernels and roms...and deciding that this looks like the most competent and current info, my question is this:
If by following original posted instructions, will (1) I be able to over clock my wife
Great, thanks...next question. User friendly rom suggestions *for my wife?Yes, once rooted the Eris can be overclocked. However some (many?) of us are finding that with a decent ROM overclocking is not necessary.
Yes her contacts will come back IF (!) they are set up as 'Google' contacts. If they are 'Phone' then they won't be restored.
Let me start off by saying I am sorry for being a dummie. So I try to read up on the Root for Eris for Dummies, but the hole just keeps getting deeper, every step brings me to another thread and I am getting more confused. I am even confused on downloading the Plain Jane ROM, with different options from the link on first post. So I am not sure what I am downloading ? !! I am a total noobie as everyone can tell. Is there a very very dumb down thread step by step to root the Eris. Then theres the A Ron Recovery, nandroid recovery and titanium backup and other special wipes I need to do. It's making my head hurt. I only want my phone to work like a regular phone, so damm slow. It is so slow when I press call and it dont do anything, I press it again and after some time, the stupid phone has placed 2 calls to the same number. What happened to my phone ? Maybe it's beyond my capabilities. I am thinking of not pursuing this rooting thing any further.
), you should take a Nandroid backup first so that you can restore should you need to. See figures 33-37 in this very same thread for awesome instructions and pictures regarding doing and how to do this.
First off I want to say THANK YOU Scary Alien for staying up late and typing up that extensive reply to me. I am sorry I kept you up. So I feel a little braver today. I guess I just had to sleep on it.
One question I had was the step where to check the files MD5 checksum. I am a bit lost on that. What am I checking the gscript file or the Plain Jane ROM file. Am I checking it at the megaupload site or the file on my computer as compared to the checksum afterwards on my SD card ?
So I am ready to pull the trigger so do speak
Thank You
D). Read through this thread: http://androidforums.com/htc-droid-...checksums.html?highlight=verify+md5+checksums
). The MD5 sums (and the file's size) just let you know that you've got a full, complete, and uncorrupted file. Hopefully, the publisher of the file has posted the MD5 sum and size of the file so you can check on it after you download it and after you put it on your phone (/sdcard) (or where ever it ends-up being).Only thing I can think of I have messed up is in order to prevent the screen from timing out out I pressed on the body of the script. But I did not add anything. Can start over or ?
I re-read forgot to turn off the phone between steps 1 and 2. I will turn ON phone and hope thats it.
Update: Still no go after turning phone off and on. Do I need to wait longer with power off or need to pull the battery.
I will wait for instructions from the experts.
Thank You.
THANK YOU Scary Alien, I DID IT, I rooted and running Plain Jane, trying to remember how to setup my yahoo mail ? I hope I can copy the settings from my wifes phone. Now I can go to sleep better tonight.
Thank you so much scary alien. You were my crutch on this very scary procedure. Hope you have a nice Labor Day !!!!!!!!!
Thank You, Thank You, Thank You !!!!
 [be sure to thank erisuser1, too...he actually did all of the heavy-lifting].
, as I was when I rooted (but I didn't know eu1 yet and did it the "old fashioned way" (well, it was actually a combination of methods, lol)).I have possibly a stupid question, but I can't find anyone that talks about this. I rooted my phone and installed a custom ROM and I feel that my phone actually works better! Smoother texting, no more keyboard lag, its awesome.
My question is this, since I wiped my phone, how do I go about intalling a different ROM? Is this process easier now that my phone has already been rooted?
HELP PLEASE!
I have loaded gscript to the SD card. How do I launch it?
I am stuck at "figure 19".
Thanks!!
Before you get started, please review this checklist:
1) Did you choose a ROM, download it to your SD card, and check the MD5
   signature/file length on the copy of the file on your SD card?
[COLOR=blue]2) Did you install from the market the free apps "Gscript Lite" and [/COLOR]
[COLOR=blue]   "EStrongs File Manager"?[/COLOR]
3) Did you download the "[COLOR=red]gscript.zip[/COLOR]" file (link above) using the phone's
   browser?
