[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
So im about to clean flash:
Sourcery v2
Justinbean inverted Gapps 8/21
I hear these two are working together...
Be back with my results shortly :)
quick question for my fellow magicians... Im trying to use lightflow for custom app led and i see theres a led app control mod in the control center but i cant figure out how to work the control center app in question. How do i set that so I can utilize lightflow (or is lightflow even needed with this rom)?
So what is the file size of 2.0? My phone downloads it until it hits between 65-75mb then it says it's complete. I've tried downloading 5 times now and have gotten different file sizes every time :(
Same problem with v2 that I had on v1... clean flashed the ROM with justinbean inverted gapps and I'm missing my flippin phone app. Everything else works but no way to find the phone.
Ughh any ideas anyone?
I'm still using Light Flow exclusively. I haven't dabbled with the ROM's light functioning.
So I'm completely new to all of this. By new I mean I got my nexus yesterday, learned all I could about rooting since then, and rooted today and made this my first rom. So far its amazing but anytime I try to use a different lock circle the phone crashes during the install and I have to pull the battery and restore. Any advice or explanations for this?
what do you mean by crashing.
for some reason with JB. at times when we force a root the google will sit there for like 3-5 minutes and than it will boot we are trying to figure out the reason for this.
hoping when verizon releasees jb for it the bootloader they release will fix it. this does not happen on the gsm version.
so if its just you think its stuck at the google screen just wait lionger.
if thats not it whats it doing?
Before the install of the circle finishes the phone goes black and just sits there. It won't turn on and it wont boot to fastboot. When I pull the battery then try to turn in on normally it will go to the google start screen, then go back to the black screen where nothing responds. The only thing I've found that works is to pull the battery, go to fastboot, and restore from there.
when installing the rings it will automatically reboot. than as i said at times it will sit on google logo for liek 4-5 minutes..
this does not sound like what your describing.
I have never seen or heard of this happening so i really am not sure what to say.
Hey eagle I wanted to ask, would it be at all possible in future builds to be able to have an option to delay the reboot when installing certain mods. For example, if we change the lockscreen circle logo, the phone reboots immediately. Is it possible to have a "reboot later" feature so that we can choose multiple mods before having to reboot?
I saw this earlier..was at work...
I dont like the idea because of the possibilities of corruption it could cause as you seee occasionally that always happens becasuse of the way we manipulate the files live. rather than replacing the whole file causing them breakage and such.
But i will discuss this with devortex and see what he thinks.
I havent seen any mention of the back ground image changes live. ability to put your own choosen file on pulldowns or on the background images. you all have seen this right. ? :)
Hello,
I would like to give JB Sourcery a shot this week. For those of us that haven't flashed it yet, I believe JB Sourcery 2.0 is released, is there a clean download we can do via our PC or do we need to download 1.0 and update via the ROM?
Version 2 Special features--
Background image changer ours or yours-live changes.
Pulldown image changer ours or yours with tranparency settings
Weather lockscreen with 10 and counting different weather icon sets .
Led controls with custom app settings
Lock screen targets custom settings
too many text color changing abilities to list.
JBSourcry Info center..when we have tips/tricks,links,troubleshooting whatever!!--Having a problem check the info center to see if a fix has already been explained.!
Lol, magic niple pull down
you can set it to be the background image also :)
we are working on a mod that will switch the power button and headphone output to the top of the phone and the usb charger to the side as it should be..
having a heck of a time not sure when it will be released.
Don't forget the sd card slot!
