satellitez
Same here, download is super sluggish
just an fyi, we went life with Eagle at his day job
he will be working on things tonight when he gets home..
We are aware of a few app wallpapers that pull the same image... Chizzele will fix when he gets home... The soft key button 1 doesnt change when using a tmobile theme, this wasnt the case in version 1...
If you see anythign else, let me know will add it to our list.
thx again for the great support here!
Eagle will have to answer that one.. not sure if its possible or not
I got the message but don't know where to get the new version. Same site I got 1.0?
No, its fine to do after gapps. So go into system/app and rename your original youtube.apk to youtube.apk.bak and then paste in the inverted one. Rename the black-youtube.apk to youtube.apk
The playstore one, renamed to phonesky.apk
Atrain, hit the "here" in the message and it will start downloading
EDIT: It downloads to the Sourcery Tools folder, not the Download folder. Keep that in mind when you go to install it...
Crap! I think I cleared the message, because I don't know where it is now. Punishment for my own stupidity!
Go to settings, then JBSourcery tools and the rom option. It'll be in there.
So much thanks to you and Chief. Phew!
So now the question is...Dirty or Clean?
