[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
Themed pandora is actually white when in app. But the widget looks better with some transparency.
The flashable mods are all inverted. Black, white and ics blue.
Only things is the gmail inverted flash. If it doesn't work at first, go into phone settings > manage apps > all > Gmail and uninstall the update.
Again, if u want pics just gimme a holler.
Would it be possible to get a pic of the Gmail, PlayStore, and Youtube please? Those are definitely my most used Gapps. Thanks satellitez!
Here ya go gmail, youtube, playstore.
In gmail the to/from names are gray while message font is white
Brain is fried already this am from work so gonna ask a dumb question..... :-) what apps/functions do you use that for
When I'm typing an email and tap near a word I want to change its easier for me to navigate to the actual space using the volume rocker than messing with the arrow.
Back on AOKP... I like this ROM, but, trying some mods and got stuck in boot loop. Had to recover, will try again later, love all the mods, must have had a bad combo...
So..bad download by me? Should I reinstall Rom...or do miss get downloaded separate when you decide to install them?
What about Detroit tigers mlb lock ring?
Is there something that I'm missing. I tried installing the APKs (Play Store, YouTube, etc...) but since they're already installed, I can't install them. Are these something that I'd have to installed before flashing Gapps when flashing a ROM?
No, its fine to do after gapps. So go into system/app and rename your original youtube.apk to youtube.apk.bak and then paste in the inverted one. Rename the black-youtube.apk to youtube.apk
The playstore one, renamed to phonesky.apk
Sourcery developers,
Any way u guys can add a teleport mod?
That way I can select to zap over to Fiji for the day. Then tomorrow I shall zap over to Paris just for lunch.
I'm noticing that the screenshots posted so far have the bottom menu buttons looking sort of neo-futuristic and streamlined, but I'm not really a fan. With all the customizations, I'm sure this is an obvious question, but I just wanted to make sure - are those fixed?
Okay, I am officially bewildered by some of these options.
What are lock screen glow dots and Pull Down mods? :confused:
It would be oh so helpful if the devs had an intro blurb in each mod section describing what the mod is and what it does - hint hint ;)
