Such as ? If you can give some specific, might be able to help
This is a splendid rom, dont get me wrongFirst off, i hope im not coming off as ungratefulThis is a splendid rom, dont get me wrong
The homescreens stutter a bit, transitioning from app to app will hiccup and stutter, scrolling will stutter occasionally as well.
my guess would be all the crap ton of mods i use?
I'll try to provide some answers....
1. Light Flow LED works fine with the rom, since it a popular app and can do so much we added just basic LED functionality with the rom.
2. If MMS wont send over WIFI its either a WIFI network limitation or a culprit in your MMS app, clear cache and data of app to find out which it is.
3. Lock Screen calendar not included yet.
4. If you apply a mod that wont stick it is most likely related to a theme engine theme that you have applied.
5. MD5's are different now as we added a small edit to make the rom compatible with goo.im - that minor edit generated a new md5.
6. More lock screen rings will be added
7. If you are flashing other gapps and lose phone its because the contacts app in those gapps is not compatible, pull ours out of the zip and replace with the incompatible one and reboot.
i have noticed some of the images are kinda badly cropped, or edited...
i seem to notice the boot animation a lot on that aspect. I LOVE THIS ROM
customizing this beast is amazing. I just cant seem to get over the whole image issue
Was on WiFi in a hotel..could very well be the prob. I'll test it further this week. Not like I get many mms anyway!I'll try to provide some answers....<br />
<br />
1. Light Flow LED works fine with the rom, since it a popular app and can do so much we added just basic LED functionality with the rom. <br />
2. If MMS wont send over WIFI its either a WIFI network limitation or a culprit in your MMS app, clear cache and data of app to find out which it is. <br />
3. Lock Screen calendar not included yet.<br />
4. If you apply a mod that wont stick it is most likely related to a theme engine theme that you have applied. <br />
5. MD5's are different now as we added a small edit to make the rom compatible with goo.im - that minor edit generated a new md5.<br />
6. More lock screen rings will be added<br />
Someone link me to the contacts zip? Please?
Anything I can do to fix this? I like my uber jelly theme but it's making the softkeys go fubar. It also reset my pull down wallpaper a few times as well as my home screen wallpaper. Kinda defeats the purpose of even having a theme engine.4. If you apply a mod that wont stick it is most likely related to a theme engine theme that you have applied.
Also is causing a weird glitch when im in root explorer
When I plug in my head phones the audio level goes to half. Every time. I know this was an option I could disable in CNA. but haven't found where it lives in this ROM. Any ideas?
ok...........what would the glitch be.?
We have it mentioned in every area we can think of that the theme engine and our mods are more exclusive..its one or the other.
Out themers are working hard now to get our theme manger going.
For now, i will disable my theme and and enjoy the magic. when installing the rings it will automatically reboot. than as i said at times it will sit on google logo for liek 4-5 minutes..
this does not sound like what your describing.
I have never seen or heard of this happening so i really am not sure what to say.
Sorry, fell asleep last night. Do you have Light Flow enabled under settings?
yes i have it enabled under accessibility and under the led control center also butttt when i select the flash while screen on option the led just flashing whether theres a notification or not and idk what the deal is?
