[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
Is there any way to enable us to change the wording at the bottom of the drop down? Right now it says Verizon Wireless. I forget what rom I was using that allowed it but it was kind of cool. It's small and incidental so I understand if it's a PITA.
There sure is......In JBSourcery Control center > Magic UI > Custom Carrier label
Click on it and type anything you want and Shazamm!!!!
Edit ----always read all posts when catching up... never know when eagle is gonna answre a few posts below the one Im reading lol
You will never get a rush out of me..I'm grateful for even having the Rom.you guys do great work.glad I decided to try it, and with the mods"baked"in and the awesome support, don't think I'm going any where else for a while
So... anyone else having issued with the menus? I was thinking about doing some more customizing today, but my menus are empty. Like under "animations" it will say that its loading, but then comes up with a blank screen. Anyone else?
Seems to be all menus... weird???
First, let me say that this ROM is incredible and I almost get lost with all of the customizations. You and your team have done a great job, thank you!
One small bug I have discovered is when I check the box for "Vibrate when ringing" under sound options, when I exit that screen and go back in, the box is then unchecked. It is a minor bug, but one that I use on my phone. I like to have it ringing and vibrating simultaneously.
Thanks again for the excellent ROM!
yeah that just happened to me but then I tried again and they came up. not seeing any of the new lock rings though yet
No problem at all! May I request an Atlanta Braves lock ring be added sometime in the near future?
Thanks again for an amazing ROM!
Could we have these made into lockScreen rings please?
Many thanks :)
I finally decided to flash this and so far I'm loving it. The only problem I have is that the fixes at XDA to fix the photos not showing in gallery issues does not work for this ROM. (Many people Suffering Gallery/music Issue - xda-developers
I guess I can just use QuickPic but if someone has a fix can you please point me in the right direction?
Thanks you... Awesome ROM
go into the tools app than find mods about 3 over..
install the no media fix reboot and see if that fixes it . if that doesnt fix it than install the gallery mod there that doesnt say stock.
see iof those fix your problem let us know.
Thanks man... I however found a fix here: Your Missing Pictures, Songs, etc. is due to ROM Manager - Android Forums at AndroidCentral.com
Apparently the new version of ROM Manager is STILL causing this problem. I wanted to share the link in case someone else is going thru the same issue. Process is simple but you have to boot into Recovery and wipe catche and Dalvik.
I did find that my choice of boot animation doesn't stick. I get the Google screen, then a black screen. Then it boots.
CC > Navigation Bar > Button Glow Animation > Off
...does not work for me. The glow stays on at what appears to be a normal setting. I ended up going with (and likely preferring) "damn fast" anyway but just wanted to report it.
I have found that I no longer need ROM Manager. Anything I used to do with it, I can now do manually or in the JBSourcery options. If ROM Manager is causing you headaches, try not using it for a month. You may find that you're better off doing things old-school and just not worrying about fixes. My 0.02 :)
Anybody having any issues getting DSP Manager to work. I have it checked off in music effects but I cant seem to get it to do anything.
