DoctorEyeSight
It is the same issue I was facing with JB Sourcery V4.1 and now with 4.2.1
An issue I am having is when I send a picture through text messaging, it says "sending" and never sends to the person. Days will go by and it will say "sending."
read chizzels post, if your sending while on wifi, that may be the cause of the trouble.
I had this same issue quite a while back. I was using Handcent though. Got rid of that and been using the stock messaging app with no problems.
Which gapps?
older gapps.. try the 1216 gapps... should see an improvement
Would it possibly be a cache issue?
Edit: FWIW, I'm wiping cache/dalvik to see if that helps.
