[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
Are there new radios I should flash along with 4.2.1? About to flash this ROM tonight. Thanks.
I have ROM manager ClockWorkMod Recovery 6.0.2.3, is this fine or TWRP? Or same? I have always been using ROM manager ClockWorkMod Recovery. Thanks.
I can't find the download link to JBSourcery 4.2.1 through JBSourcery website. Can anyone please link me to it's download? Thanks.
you do not need to install any different radios....
I never recommend using rom manager.. boot into CWM to install manually.
Team Sourcery Forum • View topic - JBSourcery V4.1 - LTE - Official Release
under the section titled "Downloads" is a blue JBSourcery 4.1 that is a clickable link.
I have ClockWorkMod Recovery 6.0.2.3, so I'll just use that as I have been using it all the time. I just read somewhere that TWRP should be used instead. But I think either one will be fine, right?
Is that link the official release of JBSourcery 4.2.1 or is that like a pre-release?
Thanks.
well, the link is titled
so henceforth we shall call it... the official release...
Please hold the applause.. I joke because I kid... :)
First of all, this rom rocks! It's running like a champ on my phone and I haven't experienced a single problem! I just started playing around with adding a 2nd user and it seems like it's killing my battery. Is anybody else experiencing this?
Hey everyone!! Is anyone having an issue where they are no longer getting their calendar notifications? I am no longer getting the notifications like I did.
I clean installed this (factory reset, etc...) I haven't added any mods or anything. I was just surprised that my calendar notification didn't pop up like usual.
Thanks!!!
An issue I am having is when I send a picture through text messaging, it says "sending" and never sends to the person. Days will go by and it will say "sending."
Thanks!!!
Which gapps?
I've had this problem, both with this ROM and others. I've never found a fix, so I just email photos instead of MMS.
If you are trying while on WIFI, please switch to 3g or 4g and try again. That is a common issue to have while on WIFI as some routers have the sharing media files from mobile devices blocked by default. If it a work or a public network you are trying this on it is even more likely.
Let us if it works on mobile data as it should... this is more of a wifi issue and not rom related in anyway.
