My laptop connects immediately.. cant try my tablet as its wrapped and under the tree already![]()
hmm..not had that issue myself....I haven't seen anyone else with an issue with waking the phone up with either power or volume rocker. It reminds me of my book colors sleep of death. I was on 4.0 and just updated to 4.1(cache wipe only) right before this post. Hopefully something had changed to fix this. If I were to get a logcat with alogcat, what settings would I need to use?
I'm with you on that one..... mine is under the tree... hoping devortex gets to the N7 as he has claimed...please father Christmas let it be nexus 7 and get this goodness running on that bad boy!!!
Gonna do a re-wipe tonight I think, since I found myself with an interesting one. Not entirely sure how it happened, but I had went to install the addon.zip and the camera bitrate increase one. Seemed to install fine, but as soon as the phone restarted, realized that now I cannot access the JB Control Center. It just black screens. I get the shell message at the bottom, and it just sits there. Messages comes up about once a minute, and just repeats that, no matter what I do, until I restart the phone. Unfortunately, I have no idea how to possibly correct that, other than just wipe and start over (I only had put a few apps back on, and hadn't made any big enough changes that I needed to make a backup for yet).
Weird. gonna get it back up and set, and then see if I can replicate it.
EDIT: Hmm...seems to have affected anything requiring root. TiBu is doing the same thing, sitting at "asking for root rights" and every 30 seconds or so, flashing the permission message again, and loops that way. So...that's a bummer. Looks like I'll lose some info along the way. ugh. Well, whatever...
dirty flash rom/gapps/// sounding like you have lost root access, possibly.. very odd.. this should correct it thoughGonna do a re-wipe tonight I think, since I found myself with an interesting one. Not entirely sure how it happened, but I had went to install the addon.zip and the camera bitrate increase one. Seemed to install fine, but as soon as the phone restarted, realized that now I cannot access the JB Control Center. It just black screens. I get the shell message at the bottom, and it just sits there. Messages comes up about once a minute, and just repeats that, no matter what I do, until I restart the phone. Unfortunately, I have no idea how to possibly correct that, other than just wipe and start over (I only had put a few apps back on, and hadn't made any big enough changes that I needed to make a backup for yet).
BT issue seems to be a range thing, so now I can at least remember to turn off the speakerphone before I leave the car. Only other random thing I had happen, was after the BT hung on Turning off, I restarted the phone, and the wallpaper I had set (one of the Sourcery ones), shifted. Normally static in the placement, it seemed almost like it had scrolled a page. Just reset the wallpaper and was fine. No biggy, and likely a random one-off.
I always say, try a lot of different roms.. find what works best for you and the way you use your phone. Sourcery is my fave, but there are many great roms out there!
I hate to beat a dead horse, but I'm still having proximity sensor issues! After a random number of calls, the screen goes blank when I make a call and will not come back until I push the power button to end the call (I have it set so the power button ends the call because I had no other way of hanging up), and then press it two more times to get back to the lockscreen. The only thing that resets the sensor is a reboot with a battery pull. The problem repeats itself after a few calls, so it's really becoming annoying!
I don't think the sensor is defective, and I don't have one of those GNexes that was built August-September 2012. I've recently tried using prop modder to change the proximity sensor delay to zero, but I'm not sure that setting is going to hold.
This started to become a recurring problem when I installed 3.1 wth the updated gaaps on your site. The previous release I had (2.3.5) I used the gaaps released 07-26-2012, and that was the last time the proximty sensor worked without fail.
Is there any way to use an older stock dialer on Jelly Bean 4.2.1 than the one in the standard gaaps file on your site? I tried to find one on the web, but don't have the tech saavy to get the right one. I'd like the one that had a white backround. That's the last one I had where the proximity sensor worked correctly.
Hope I'm not being annoying, but I really love your ROM and don't want to have to go to another one because of this. PLEASE HELP!
