If you mean the sourcery servers, yes. This is the Verizon section, though. You'd do better in the sprint gnex root section.![]()
Can't use the 4.3 themes with the exp, right?
I finally updated a couple days ago....of course I love it as I have all other Sourcery builds. I only have one question/issue - my lockscreen intermittently has a delay in appearing after hit the power button. It's almost as if it has to think about it - it eventually shows up but not before I've wondered if my poor phone has an issue. (Yes, I tried a second clean install to make sure it wasn't anything I had done the first time) Any ideas?
I've read about this issue across several Gnex posts. No answer for you, but mine did it too.
Wow, BB, I thought it was just MY phone! I have the same delay![]()
I am seeing it as well.... will check with eagle on his return from vacation
I didn't think anything of it as I've noticed the delay on every rom I've ever used. Huh.
Shameless multi-quote bump of this particular issue. Just wondering if this has been addressed, is still present in JBS (and other ROMs), and if so/not, the root (pun intended) cause of the issue. Quickaudi's inquiring mind wants to know!
Just wanted to chime in and tell the developers thanks for a truly impressive ROM they've created in 4.4 experimental. The amount of features are crazy! Finally a rom that makes me happy to be on android 4.2 and not miss the 4.1 days. Once the lock screen torch gets working better (very nice to have when it works) it'll be perfect. Thanks again!
This happens due to the new lockscreen widgets the more you have set up the more the delay.
In 4.3 we had allowed up to 10 lockscreen widget pages and this may have caused an increase in this dealy.
it appears most are putting it around 7-9.
Stock is 5 and i went back to that. but even if you set up all 5 pages you will see an increase in this lag. with none set up i dont see it at all. but of course i dont expect my phone to suddenly turn in to a 12 core intel processor so maybe i just dont see it.
what is coming with the 4.4 release is best i can make it.
I am, as usual, the odd one .....I have no lockscreen widget pages (and no shortcuts either) and it still decides to hit the snooze button some days. Like I said - not a big deal, I'm not leaving for something like that.
