My Bluetooth had done the same thing. UN paring and re paring fixed it. I still have to reboot to get the gps to lock though.
The maximus gapps have more inverted, I havent loaded the minimus version so cant tell which apps are vs arent inverted
I know that it has pandora inverted, as I use it often...
Okay, so the maximus has inverted gapps plus some other 3rd party apps? And minimus just has inverted gapps?
I'm at a toss up between eagle #2 (sourcery) and leanKernel (latest exp 5.7, i believe).
BTW, 4.2.2, as far as I can tell is a hoax. Over at Rootz they locked the thread.
Did you have to install gapps with the patch?
Still in the process of backing up...I need an app to ready myself for new ROMs.
Any app developers want to tackle this? The app's core functions would do the following:
- Check for and install app updates from Google Play
- Run Titanium Backup > Backup all user apps and system data
- Check for, download, and install latest TWRP recovery
- Reboot into recovery
- Set appropriate backup name and run backup
- Boot into system with notification showing the above has been successfully completed
Okay...so I know I'm dreaming...but wouldn't it be nice?![]()
I recently switched to Sourcery and will have to give this a try as i am really enjoying it so far
I love being able to easily switch between kernels though![]()
