Gapps have been updated.
The Minimus gapps had a bad talk.apk so I replaced both just to be safe
I only flash about 15 times a month![]()
Which one did you flash, 180 or 230? I'm still on sock kernel and the battery could be better. Only ROM i found with good to better battery life is Eclipse, but it lacks some features only Sourcery has.... That I know of...
Actually, try the new air kernel nightly #483. It's getting me better battery and less lag than lean.
Atom Rom has the best battery life and virtually no lag, but not many features. It's always a trade off.
Did the custom brightness settings go away in 4.3?
Someone mentioned that there was a setting to swipe down the right side of the screen to go straight to the toggles? Where is that setting found?
Also, an observation: In landscape mode, the nav buttons tend not to work very well. Even a quick tap tends to trigger the nav bar ring, and then whatever app I've assigned to usually #1 or #5. This happened to me in 4.2 too.
Great stuff as always, despite minor quibbles -- thanks!
Custom brightness is still under display, also can swipe across the notification area to change the brightness
you can use 2 fingers to swipe down to go straight to the toggles.
Landscape and nav bar works fine for me.. not understanding what your meaning here.
thx
The two fingers thing may not be working for me because I have that assigned as a Nova gesture. But I'll try it next time I see a notification anyway.
I'm running out of tricks here. I am installed 4.3 using a clean wipe and standard 12-12-12 Gapps. Still having a devil of a time with my Bluetooth. It drops, controls don't work, total pain. Please advise. I may revert to 4.2 as an experiment.
Sent from my Galaxy Nexus using SwiftKey Flow
