I don't see a toggle widget...where are you seeing it?
Menu -> JB Sourcery Control Center -> Navigation Bar -> Navigation Bar Settings
Pick one, it pops up "Button # action & icon." 6th one is "Toggle Widgets." Select it and the Sourcery icon comes up and reads "Navigation Bar Widgets." Doesn't do anything when I poke it, though.
Still can't find the phone under applications for either the nav bar or lockscreen either?
I'm thinking I farted something up since no one else seems to have these issues. But, if it helps:
I came from Codename (which had the same Toggle Widgets issue too, but again no one else seems to have said anything), wiped via Superwipe, flashed Sourcery, flashed Sourcery's gapps 7-26, flashed Justinbean 8-24 inverted gapps, and flashed TiBu update zip. Booted, restored device ID via TiBu, rebooted, restored apps (user only) with TiBu and set up from there.
I tried flashing the inverted gapps without flashing the regular ones first as well, but I still didn't get the dialer.
::shrug::
Edit: Looked in system/app, and sure 'nough Phone.apk is there. Installed, but still no dice.
OK, sorry for the really dumb questions but I can't figure these out and googling hasn't heklped... I clean installed, and flashed justinbean's inverted gapps.
I'm trying to set up custom navbar buttons and want one to be the phone. I can't find it -- not in the stock options, not in "custom application," nor in "applications." I know it's there somewhere, because I can dial from my contacts. Where is it?
Am I also missing something about the "Toggle Widgets?" It doesn't seem to do anything. AOKP ICS had an area where you define the widgets, and I don't see that, so I'm guessing it's a placeholder? (Or, more likely, I'm looking in the wrong place)
Thanks again!
So where do minor annoyances go in regards to the theme and the dark gray background with black type on some things. Makes typing anything very hard to do in some things.
Thanks again!
just tell us wht theme and what your seeing we will get the info to the themer to fix it.
When I plug my headphones in the volume is automatically at 50%. I cannot seem to find a "Safe Headset Volume" option though. Anybody know if there is one somewhere or a workaround for it.
Thanks
coming soon
too laggy, battery life not so great, and the back button kept returning to stock after i changed it to zenith.
went to xenon hd project x (best battery life of any jb rom for me so far), will be back if version 3 sourcery fixes these issues.
Entire NBA lineup added to toolbox and is available to use as lockscreen rings... if anyone asked for a custom add on to that area and was not answered or not preformed... please ask again as it was a very long week at work![]()
MLB lineup will be done tomorrow...
lolStill hoping for the FS of the Florida state university. Thanks.
Good morning!
Don't ask me why: but the way you guys are cranking out the goods I half-expected to wake up and find JBSourcery 3 ready for download!
Ah well, maybe tomorrow![]()
Wanted to say thank you to everyone at JB Sourcery. This is a wonderful ROM. Glad this was my first JB ROM.
Anyway I was wondering if you guys could add the stock galaxy nexus boot animation? I couldn't find it to dowmload in tools.
