[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
I believe it broke my LED controls. I've been using Lightflow with this rom for ever, but with my latest clean flash and MBP restore I can't quite get Lightflow, nor the built in LED controls to 'stick'.
'sigh'. Off to a cleaner flash or to wait for 4.2 . . . . . . .?
Ah yes. I tried a clean install of 3.1 with the standard gapps package, hoping I could then go forward with the inverted gapps package, but, after the automatic restore of my apps with this method, still my LED is broken. It worked just fine with JBS 2.4 so I have now restored to that, for now.
What is the Galaxy S3 transform package? The large file under "mods". What does it do? And yes, please put up the stock camera app in case we hate the new one! Freaking love this ROM!!!
Okay, Dear Developer, time for the Ol' Chief to to learn a new trick:
HOW do I generate a logcat? That way I can post it and we'll figure out why my son's Nexus keeps turning itself back on.
BTW THANK YOU for the 4.2 Camera and Gallery mods! While photosphere doesn't work quite as well as I would have hoped... too much overlap and it's not seamless. Maybe with practice I'll get better with it :)
If I'm not mistaken, you install a logcat app from the play store, set it up, then reproduce your problem.
dont know what you mean by its broken...
Sorry, I mean that the LED notifications don't work as programmed. In lightflow, I have gmail set to flash green, but if at all it will flash blue. If I hand off control to the rom's LED control, it _might_ work for a while, but not stick after a reboot.
And yes, I reboot often as I have a spare battery/charger. Never believed in wasting that port for charging on any phone. It's for better stuff.
How can I increase speaker and headphone volume? It is very low. I used DSP manager, it hasn't improved the volume.
Get the app volume + from the play store or for free from the website. I don't know the website but it should be listed when u go on their page when u go to the play store.
I use DSP manager and it definitely increases the volume for me. Just jack up all the bands on the equalizer and see if that does anything. Then, under Sound in settings, verify that DSP Manager is selected under MusicFX.
Same thing is happening for me. I love light glow but it stopped working for gmail so I use the built in one now. It is hit or miss whether it works either. Light flow worked great in 3.0
Just did and it is still low. Same with Volume +
On the left hand side of the phone, as you face it......tap on the top of the button repeatedly.....volume will wake your co-workers from their sleep :-)
