[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
Music will not play through my headphones despite being plugged in properly. Music will just continue to play through the speaker. Yes my headphones work on a other devices.
AFAIK Light Flow has some compatibility issues with JB. Not a rom specific issue but more of a optimization issue. Apparently its a hit and miss for many users.
Not discounting your issue and will try to resolve.. but seems to be an issue across several roms and not just Sourcery...
I know it has had issues but what I am curious about is it worked perfectly on 3.0 and on 3.1 it now has issues. Also the built in led is hit or miss. Sometimes it will work but most of the times it won't. Plus some apps it won't work with at all even though when I test it it does work. Debating on going back to 3.0 because I use the led light a lot.
unplug headphones and reboot.. turn on music and plug headphones back in.
should resolve your issue.
Had this once before myself.
When I download a boot animation where is it supposed to be saving to? Is it SourceryTools/boot? Because for me that folder is empty.
Try it now, had to resize the preview, should be working
Yep works now thanks.
Which led torch app is everyone using to get it to work well with the lockscreen? Have been using widget lockscreen for a long time but am wanting to go to the normal lockscreen that's on jbs 3.1. Is there one already in the rom or something I can use?
Lockscreen - Slider shortcuts
when it lets you select your item, choose Sourcery Magic and then choose torch once you save it.. reboot
In my opinion., a toggle is much easier
dirty or clean? I would suggest re-download and install. That was a new option that was added on 3.1
It was a clean install. Maybe I will have to re-download it. Here is a screenshot.
sounding like my install didnt actually wipe. i had some info in there that wasnt in the new release. new instructions are to set torch on lock screen, need to choose activities than you will see sourcery torch
