PhilosoRaptor
turn on your wifi... see if it helps narrow your location down
It does if I'm at a house connected to WiFi, but when we're out in town (where you normally start trying to navigate to places) it's totally broken
which apps/which ones with data? Tibu is wonderful and horrid at the same time, depending on how it is used.
on your next install.. dont use TIBU and let market restore apps. see if you get a connection in maps. I always do and I only restore game data, no apps or other data using it.
Seems everyone having odd issues that TIBU is at the root of the issue, could be coincidence.
I have faithfully used Titanium Backup Pro to restore apps & data and have never had any problems. I guess I am in the minority![]()
eagle just got back from vacation last night.. doubt he has had a chance to look at anything. would assume a 4.2 rom will be our next, but that is just an assumption on my part
1. Seems like I'm seeing maybe some issues with the Gnex using TWRP2 recovery. Are there issues with twrp2 and the Gnex?
2. If I don't want to change over to twrp2, can this ROM be flashed using CWM? Seems like I've seen there's maybe some issues with that, too?
3. Obviously, I do a nandroid first, but will a nandroid made using CWM be any good if I switch over to twrp2? If the poo hits the fan, will I be able to restore nandroid backup made with CWM using twrp2?
Oh yeah, one last question. Never changed a kernel before, but after reading here, thinking I may want to go with lean. How...., what.... where.?
Steel, the easiest way to flash TWRP is to install Goo Manager from Play, and in the menu select "Flash OpenScriptRecovery". It'll do the rest all by itself.
Lean kernels can be found here:
[Kernel] Leankernel: Minimalistic Kernel (4.6.0, 5.0.0, 11/23/12) - [VZW] Galaxy Nexus Development - RootzWiki
Thanks again, Chief.
So, sequence of events:
1. Flash twrp2 with goo, goomanager will dl twrp for me, or do I need to have it in \sdcard?
2. reboot to new twrp recovery, nandroid backup immediately with twrp2. (I don't have to wipe cache or dalvik since twrp2 is already flashed? This nandroid will allow me to return to where I am now?)
3. Full wipe, factory reset, wipe cache and dalvik
4. Flash Sourcery
5. Flash gapps
6. Reboot.
Anything else? Did I miss something? I feel like I missed something. Oh, yeah, lean. Where's that fit in?
Ha. I just noticed you live in Manchester, TN. I live in Manchester too, though in my case it's the NH variety.
EDIT: I don't know if you guys read this or not, but it explains WHY the new TWRP 2.3.2.1 is required for a full Android 4.2 ROM:
Quoted from Androidspin.com -
In TWRP 2.3.2.0 we have corrected this problem by ensuring that we do not delete the special file during a factory reset. However, if ended up having your files upgraded you will need to move or merge them back into /sdcard. Also, if you have moved your TWRP folder from /data/media/0 to /data/media so that you could restore backups while using prior TWRP versions, you may now need to move the TWRP folder back into /data/media/0.
Anyway, thanks for reading my rambling dissertation. Hope this helps![]()
