I purchased Volume+ back in December 2011 two weeks after having the GNex and have been using it since.![]()
Does the circle battery mod still work with the newer versions of this ROM? I haven't been on this ROM since 3.8but back now and just curious if it still works?
UPDATE: Yep, it works, for those that want to know...just flashed it
REQUEST: I really wished we could get DSP Manager added back into this ROM.
I have Volume+ also, but never has seemed to make an ounce of difference...everything is still low. Care to share exactly how you are using it? Maybe I am missing a step or something somewhere and don't have it setup or working right.
I am using the purchased version of Volume + set at level 10. The free version can only go to level 7.
Make sure you grant Volume+ permission with Superuser.
I would agree that 6.0 is very smooth...but I am having the Phone Idle battery drain issue again on this build...clean install...not sure what's happening. Hoping for a 6.1 soon....
didn't notice that but I do note that I can't get a GPS lock... also did a clean install.
I would also add that you should also make sure that in Settings>Sound Effects that you have salected Volume+ as well.
Hey, activity from jbdan! How's the sleep
I am always behind on this now, on 6.0.1. Everything seems pretty smooth. I wonder if ryan and I are the only ones still running this![]()
Hah not too bad...yet!Hey, activity from jbdan! How's the sleep
