ryancmatchett
Android Expert
Three questions:
1) I want the volume wake mod and I DL it from the Rootz thread and flashed it. The rocker doesnt wake the device. I tried a reboot and fixing permissions. No luck. Any ideas?
2) I just the soft key mods with batt % and everything but they dont have white softkeys. Just blue and green and red. I want to keep it stock looking. Tips?
3) Is there no power option menu that includes a screenshot option?
NOTE: I can from version 1.5. FULL wipe![]()
There are quite a few mods on the 2nd post in the Rootz thread...but make sure to follow the process below for mod install....hopefully these all work with this version!
http://rootzwiki.com/topic/28677-rom-jelly-belly-v56-08062012-jellybean-411-pure-aosp-its-all-about-the-butter/
Check here for the volume wake mod..make sure to wipe dalvik before and install then wipe dalvik, then fix permissions...some people have better luck fixing permissions in recovery either TWRP or CWMR or you could try it in ROM manager...then reboot system. All of this on a new recovery session, not at the same time as the ROM and Gapps.
http://4ndr01d.com/gnex/jellybelly/mods/
Good luck!!
