vandyman
Android Expert
Finally installed 5.1.
Everything seems fine so far except I have grey wifi and cell bars, again.
Same here. Grey.
Grey bars just means that the connection to Google is not complete...usually let it settle, reboot and a fix permissions will work....
5.2 coming tonight.....
5.2 is a good build.
I installed GApps Formula84, and what a difference it makes. << More crisp and less bloat.
Also installed Multimod(blue).
5.3 is out and it contains the new Google binaries.
Flashing now..........![]()
The 5.3 download from Goo seems to be bad. (129kb)
The other 5.3 links are okay.(131kb)
PS.. Something is wrong with Androidforums as well. The lay out is all messed up.
Got home and wifi boot loop again. I thought that was fixed a long time ago. Or could it be my dirty flash?
Did you ever apply any of the DHCP/Static settings for your home wifi? If so, maybe check to make sure they are still there. I noticed after a clean flash that my wifi went back to DHCP....
