That is not true. All you have to do is touch your picture in the Camera mode and the options appear at the top.
I will switch over to lean tonight and give it try. GPS was off during that period, at least the navigation part was. DO you turn off ALL location based services? I believe that there are 3, 2 of the 3 were on but not the one that works with navigation (I had to turn that one on after I got lost, lol)
What is the best way to tell where the drain is coming from? I can look at the battery stats, screen was first and it hadn't been on much. Brightness is about halfway up btw.
Not sure of anything else significant
I use better battery stats to determine drain, if any. Check xda for the apk For that one... I don't have it with me, it's at home on the pc.
And as far as gps... I have the top and bottom one on all the time., but the location based middle item, used for nav is off unless I am using navigation.
Also, I use the Notification Toggle app from GPlay, when it's a system app, I have a toggle for gps. That switches on that middle/nav gps option.
Also make sure you use the 5.0 versions of lean, since they are the 4.2 kernels.... Versus version 4.6, which is android 4.1.2 compatible...
Good luck!
I though ckelly had swiped left already and couldn't see the share options,
Anybody else having a problem with their power button? Mine (at times) will take several pushes to get the phone to respond. It seems to only happen when trying to wake the phone but never when I'm shutting the screen off.
I also caught my phone in a random boot this morning. Anyone else seem this?
11.0 (md5: 3cc7075bcd90ad35a8a8c462597c6b79)
updated VZW binaries
implemented Quick Settings (credit kevdliu)
fixed storage reporting error
fixed emulated storage bug
tweaked jit for performance
fixed bug with some registers that was causing performance issues
fixed bugs in profiling
fixed issue with MediaController
fixed issue with a couple buffers
fixed bug with network watchdog that was causing unneeded wakelocks
fixed bug causing lag on wakeup
improved ui rendering and caching
additional tweaks for performance
additional tweaks for battery life
use my 12/01 Gapps! (md5: 2212a4990ca4bc6cd405f3e566d4a0cc)
12min and I was all set up and running again.
How the heck are you accomplishing this so fast? You running 2 apps? Lol
Get titanium backup pro, use nova launcher to back up home screens and you are golden. Just restore your apps then restore your nova backup. You will have to set up the ROM settings again but those are pretty quick to do once you know what you want.
I just restore "launcher" data from TB pro. The only thing I have to do is my 2 widgets and MSN and 2imap email accounts. I have to find a way to do those automatically.
The rom and the apps are working well.
