[Verizon] [ROM]JDX (formerly Jelly Belly) AOSP+ - v15 (7/28)
I am not having any reboots, but I am also using lean kernel... And now there is a new Gapps... Like twin said, we're there any apps plus data that were restored maybe? Otherwise...
There is a new Gapps, which you can typically dirty flash... So boot to recovery, wipe dalvik, install rom and gapps... Reboot. Reboot back to recovery and install kernel, and mods... Reboot again... Let settle.
Thank you Ryan. I dirty flashed for the first time the new gapps. It worked great.
Is there a way to check or should I simply reflash? All I have is the .IMG file and I can't remember how the heck I got that installed.
I'm not sure if there's any real difference between the two bootloaders but 4.0.3 is bootloader-toro-primela03.img where 4.1.1 was bootloader-toro-primelc03.img.
So if you have the newer img and the sdk installed and you can fastboot flash it:
fastboot flash bootloader bootloader-toro-primelc03.img
Or I believe you can use Wug's to flash an img also. I've never used it but from what I've seen, I think you drop it into a predetermined folder and then flash it from the program interface.
That said, I'd be surprised if the bootloader was causing your woes but you never know. Seen stranger things.
Launcher is stock. Radios are JB. Bootloader is a good question.....I had flashed the new one but also in order to stop various problems had used Wugfresh to take me back to 4.0.4 and then rerooted and reflashed. Maybe I no longer have the correct bootloader.
Is there a way to check or should I simply reflash? All I have is the .IMG file and I can't remember how the heck I got that installed. Is there a .zip of the current bootloader around?
Yes... You can flash the new bootloader... Will not hurt anything to do it again. Check my Dropbox for the most current or on the rootz site in the first post...
Flashing the boot loader has fixed the reboot issues that I had been having. Now as for Bluetooth......it still disconnects when it decides it wants to. The icon is still at the top but it goes from blue to grey and it loses connection with my car radio.
Love this ROM, great battery life coming from AOKP Milestone 1 (like DOUBLE the battery life). I seem to be the only one having mild issues but I'm gonna throw another one out there any ways - my audible text notifications don't work. They used to and I haven't changed anything.
I've tried a battery pull, changing the notification, and of course, making sure that the volume is up and the notification is set to sound. It does vibrate which is not ideal but it helps.
Any suggestions?
Sorry it took so long to respond.. Out of town.
I noticed the bluetooth issue myself, and it's a known issue with the dev. I think it's a conflict between the kernel and the Rom. I know they are working on it.
In regards to the T9...the one you referred to will not work, it's an old version of the contacts app... However, willyjay has one, it's a dark version or inverted... And I tried it. Works great.
http://db.tt/Ab7ZXmMJ
Any suggestions?
Do the following: in settings... Sound... What is your effects set to?
Some phones have issues with the stock music effects program... Or you could install the DSP manager from the rootz site.....
I use volume+ free and am not having any issues... Is yours set to music fx? Or can you try the volume+ app from GPlay? Here is the link....
https://play.google.com/store/apps/details?id=com.FREE.android.lvh
Good luck!
Good luck!
Settings -> Sounds - Which effects?
Any screenshots of T9 Dark? They seem to be no where to be found- even willyjay's thread has images of just about every other mod of his.
And while I am asking questions, my battery life is great (after 6-7 hours I'm at 34%) but why would Google services be taking up 35%? I've never seen it above screen before. Granted I've only used my screen 40 minutes.
Just checking... Since I don't currently have Google services on my battery screen... But if you click on it, it might tell you what is keeping the phone awake?
I would recommend to reboot to recovery, wipe dalvik and then fix permissions in advanced settings.
I have had this happen when I did not get a gps lock immediately after installing a Rom, and my Google now was struggling to keep up with the gps locations and cards... A fix permissions and a good gps lock fixed it.
After I let it lock, I leave my gps off until I need it for navigation. And since I use the Notification Toggles app, I can turn it on and off at will....
Sometimes when I'm typing a response to an AF thread using the stock browser, the cursor position randomly shifts upward so I end up typing over previous material. It happens a lot. Anyone else? (12/2 Gapps)
I don't know why I didn't think about this. Google Now (and possible lack of GPS lock) was probably the culprit. I removed it last night and now my battery situation is different.
I have noticed that on my chrome browser... But I use tapatalk, so not so much an issue for me. Does this also happen for you on chrome?
Updated to lean 5.2exp1 no lag and less issues with turning the phone back on. Need to test bluetooth tho. My bluetooth kept disconnecting this weekend, and not happy about that at all.
Let us know how it runs on a full days use... Did you get a chance to get a good gps lock as well? Sometimes it's as simple as getting into maps and turning gps on... Sometimes you have to clear the data in Settings.. Apps... Maps...
Sometimes if the above does not get me a good lock in 10 min or so... I actually have to use an app called GPS Status from GPlay.
Also, I did a little bit of looking and although Maps is a part of the Google services that you saw... Some people are also seeing that GPlay is a big part of that. I had it appear on my battery screen this morning after several apps updated... It was not very much but I had to log into the proper Gmail account on my phone... I have 6...before it would update. And the whole time it was trying to get an update the Google Services was running...
I have noticed that on my chrome browser... But I use tapatalk so not so much an issue for me. Does this also happen for you on chrome?
I'm not sure. I quit using Chrome lately because it seemed to be using excessive resources. Im running Xenon because of this issue and I thought all was well but it just happened as I was typing this so clearly its a bug across various 4.2 roms.
Is anyone else having a problem with Wallet? Mine keeps saying set up will take up to 5 minutes and never finishes. i have fixed permissions and wiped delv. I am using 11.0 rom and 1202 gapps.
My wallet is working fine. Not sure how to fix yours... Any way to uninstall it and then reinstall, with TIBU maybe? If you want to try a new apk, let me know I can put it up on Dropbox.
I just did a clean install of everything and I am having the same problem. Can it have anything to do with the fact that I just got my phone replaced by Asurian? I loved using Wallet.
Nah, I don't think so. I'm on my 2nd or 3rd Assurian replacement and wallet works good for me.
Could there have been an issue with the secure element before you got it? Some people have complained that once faulted no more g wallet... I would hate to have that have happened here. Let me do some more looking today... Maybe just a re-root to get it to reset... I have no idea how to test that...
I am really sad!! I just redid everything. Went back to stock, locked the phone, unlocked it, rooted it and then installed 11.0 and 120212 gapps.
When I try Wallet, all I get is a white screen and then setting up Wallet, this may take up to 5 minutes, circle spinning counter clockwise and then nothing happens.
This phone just came in from Asurian. Never had any such issues with the other phone.
I hope there is a fix for this.
