Do it again, just make sure you're following the directions (format data AND format system).
I've done the install twice in the last hour so I know it works![]()
Yes I formatted both. I'll give it one more try tonight.
Chief, maybe i'll give that a try tomorrow.
Just did another wipe and format but still had the same issues. Not sure what the problem is. Never had any problem installing ROMS before.
Here's MY question:
I'm on Jelly Belly 1.5. To get to 1.6, what all do I NEED to wipe?
TIA
It's up1.7?
Good grief! Bring it!
Thanks for the heads-up... I'll see what's out in the morning, I suppose![]()
I think it would be fine, just don't hold me to itWell, it's 10:30 already and being wide awake, time to flash a new rom! I'm currently on jd's v3 and want to try jelly belly this time...would I just be asking for trouble using the cwm touch recovery to wipe and flash given all the problems other people have had? I'm not really sure how to get rid of it, so I keep putting it off. Would I be ok flashing regular cwm from within rom manager to overwrite the touch version?
Edit: Chief, thanks for the info on super wipe...looks like a good solution for my question
Not one reported bootloop issue on jelly belly build after 1.2. Hope you're not the 1st :laugh: j/kOk, still haven't made the jump yet. Been waiting on things to settle down a bit with the bricking stuff
So, Jellybean 1.6 seems to be working well right now and the current one of choice?
I use Rom Manager to boot into ClockworkMod Recovery Touch v5.8.0.2. Can you just wipe and format everything with that with no issues? or do you need to use this "super wipe" that is mentioned to not have issues with the bricking or bootlooping? I am coming from Liquid 1.5.
If you're talking about Jelly Belly 1.7 rom it is getting hammered atm.Is anyone else having issues downloading any of these .zips? I'm running Liquid 1.4 and I get "download unsuccessful" every single time I try. Must've tried around 50 times now.
Now that I think about it, the whole download issue has been here most of the time on Liquid... wifi, 3G, and 4G. Can anyone offer any help?
Not just 1.7... I couldn't download 1.6, or 1.5 before that. Nor the one in the 3rd post. Guess I'll try Vicious now, see if that works. These download issues for me aren't new, but usually if I try it a couple times it finally downloads.
Don't dnld the one in the 3rd post I need to ask dread to edit that. That is the version that has given by far people the most issues.
Please use the links in the OP as I keep them updated
Well I just referred to it as that because I couldn't think of the name.
Tried the link in the OP numerous times, still couldn't download. Trying to download Vicious now, we'll see how that turns out. Most of the time it'll get to 99%, then "Download unsuccessful."
People are hammering these servers and the hosts are not up to speed on the demand. Try late night or early morning when folks aren't on the PC.
Also be very careful about getting an incomplete dnld. Check your Md5's and make sure the file size is up to par. gl!
Would right now qualify as late night? Haha
One interesting tidbit I've noticed this morning:
I can't make nandroid backups in ROM Manager.
I prefer that method because I can name my backups... but they fail every time once CWM starts, no matter what I name the backup. So I'll try a backup in straight CWM and see if THAT works.
