Techno Tonis
Where can I get the JB radios? I assume Jelly Belly 1.7 doesn't come with them...
Not out yet. What we're using is a GSM rip... like JB said, it's amazing it's this good.
+1 devs!!!
Guys,
Don't flash JB using touch cwm. If you have problems, go into bootloader and flash a different recovery, then go through the process again.
I got stuck for an hour until I did this.
Steven
Guys,
Steven
I dunno. Seems as if there are still to many issues with JB. I may just wait.![]()
Do you like the feeling of owning a new phone?
This is by far the most impressive update I have ever flashed/received in my entire 3 year android relationship.
I have a question and I hope it doesn't get buried on this thread. I used to have 1 bar of 4G at work which used to disappear as soon as I tried to use data etc. After installing JB 1.7, I now have 3-4 bars of 4G and works flawlessly. What I am trying to figure out is if they did something here in Parsippany, NJ or if it's the radios that are on JB that are a lot better than what I had before. If that is the case I don't want to lose them when Verizon comes with their own version.
Jelly Belly v1.8 to hit soon and it addresses the low volume (well it's the original volume levels that shipped with the GN "factory"). So, like newer AOKP builds and CM9 look for your old volume levels to be back to the way you like them, boosted!
Has anybody tried Franco Kernels? I can't find any feed back on them. My battery life with the stock 1.7 is pretty bad.
