71% deep sleep is good right? (the higher the better?)
My experience after going back to AOKP was like everything is in slow motion. JB is much faster in every way, but I sometimes forget each phone and user is so very different.I flashed my first JB rom today, it was 2.2. I've gotten everything all set up and it's running well. Not as snappy as an AOKP rom for example, but similar to how my phone was stock. Got a few force close problems with apps but an app clear data fixed them all. 4G, 3G, wifi, SMS, MMS, phone are working normally. Google Now (voice search) is the best I've seen on any phone. I can talk completely normally, no slow or over enunciatiing like it was on all my 4.04 ROMS. Haven't had time to build up any cards yet.
I just uninstalled it with root explorer...ehh maybe I just deleted it with root explorer. Either way, remove the one installed with root explorerWhat did you do/use to uninstall it? Every time I try with TiBu the screen freezes up
Really? I haven't been over there today I'll check it out. Using it right now and enjoying the equalizer. Working 100%Good Morning Jelly Beaners!
You know, JBDan, I'm reading the comments on that DSP zip and a lot of people are logging it as a fail. I'm interested in what the consensus is in here on it... especially the 1.9-2.2 dirty flashers.
Almost ready to flash 2.2, waiting on the green light!
EDIT: From Jake Day, the Jelly Belly developer -
"2.2 has some improvements over 1.9 and a few things were tweaked to enhance performance, but if you're happy with 1.9 there's no problem staying there."
I knew you were a safe playerBut I LIKE being on the bleeding edge.
Oh well, since I'm just starting on JB I guess I'll take safe baby steps for now. Wiping and flashing now.
Make sure you're getting a deep sleep. Download cpuspy free from market. Open it. GO to settings and reset timer. Turn screen off and set your phone down for 5-10 minutes whichever you'd like (longer the better but 30 minutes is long enough). Open it up and see what it is doing. It should read in the ~90% deep sleep. If not your phone isn't sleeping properly and is probably caused from the JB gps/map awake issue. My battery life on JB is about the exact same (maybe a tocuh better) as it was on my tweaked out underclocked franco aokp b40.I will be honest, my battery life is less than stellar on 1.8. Taking a hit over stock. (Although it could just be calibration is off. Will let it run dead today to see)
I can't imagine any reason no. Have you rebooted? Maybe just some weird coincidence? Since you had to reboot to flash it in cwm/twrp maybe give it a minute? Or have you done the gps/lock fix yet to sleep your GN like a baby? My phone is as fast as fast can be after the DSP flashWell JB DSP works great now...but is there any reason why flashing that mod would decrease performance? I flashed and there's now a noticeable lag that wasn't there before which I know makes no sense...
Good morning sir!
I don't see any comments on rootz so I assume you read about fails on xda? Take them with a grain of salt
It works el perfecto for me ymmv. I dnld'd, removed the dsp that is in 2.2 with root explorer, flashed the zip I linked to on xda, reboot, voila!
First I would see if the DSP that comes in 2.2 works for you. Open it and enable it and go into the equalizer and adjust. I doubt it will work and will FC on you, but check it out.Good morning to you, too!
I haven't removed anything from /system in awhile, so advise me if this procedure is wrong:
Wipe cache, dalvik
Flash 2.2
Flash gapps (Proper)
Reboot, stabilize
Root Explorer, rename DSPManager.apk to DSPManager.old (or move it, whatever)
Boot into CWM
Flash new DSP
Reboot
Did I miss anything?![]()
Whatever happened to the talk about the JB "no nav bar" mod? I thought that was in the works.
If it does FC after messing with it a bit, then yes follow your steps except that you would need to dnld the DSP fix first as your first step![]()
Lean Kernel =)EDIT: Also, JBDan, if you could point me to this Lean Kernel everyone's raving about, I would be most appreciative!
Hey I try :shakehands:You're a gentleman and a scholar, JBDan.
Or, if you're anything like me, at least the scholar part
sneakking is head project designer on that discussion and I haven't seen him post anything on the matter. I did point him to the inverted gapps ROM on xda so awaiting his reply and advice forward on the fullscreen mod
button savior dev is really dragging his feet getting an update out, looks like he's been working on a smart task bar project, so may be preoccupied, i have already reminded him once, and may again soon
as far as the inverted gapps, everything i've seen is for the gsm version unfortunately....but if someone has a vzw version i'd be happy to try it
I posted a while back about the Transcend ROM @ the XDA. It has blacked out gapps and might be something you'd be interested in
Is 2.3 dropping any time soon?![]()
Patience my young padawan
Have no word on it, but it'd only seem proper as daily releases are the MO
That I do not know. And DSP works great for me did you try the fix?What might it include? Everything save DSP Manager seems to be working just fine!
By then we'll be to 2.4!I know right. I just dont want to flash 2.2 to have to turn around to flash 2.3 lol.![]()
