I have flashed 2.1. Needed to flash the wifi fix though as it was apparent that signal and wifi signal were weak. So far so good!
Next issue was that after a reboot, I was stuck at the Google logo. This was after having rebooted already a few times, weird. I read on Rootzwiki that you need to wipe cache when/if that happens, so I did. Will keep y'all posted if it happens again. I had just setup Lightflow prior to the reboot, so not sure if that may have caused it or not.
:flute: ...waiting...patiently....for Stevens report and thoughts![]()
Did you do a full complete wipe before you flashed JB?
I haven't had the "need to wipe cache on each reboot issue" on any of the versions (though I've yet to try v3)
I'm sorry. I've been so busy with guide stuff that I haven't even gotten around to download the Rom!
This is the longest download in the history of downloads. Anyone have a mirror?
I think I will stay on v2.1 for now, seems to be working good for me.
That is where I'm at. It's solid. He introduced a lot of new stuff in v3 including a custom kernel so I sit, I wait for the testers (I've done enough testing for now!)
I still like to dnld all the builds. As time rolls on we'll find that often newer builds can get buggier so I like to have a copy of each
Just to be clear, which rom are you using?
JD's v2.1, but restoring a backup right now to aokp b40. Will clean flash back to v2.1 in about an hour trying to play with some things![]()
For those keeping score at home, I have gone from 2.0 > 2.1 > 3.0 all dirty with no (apparent) problems.
Lol nice man! You mean this rom here right? [ROM] VanirBEAN (FORMERLY JD's JELLYBEAN) [EVERYTHING FUNCTIONS+OPTIMIZATIONS] - [VZW] Galaxy Nexus Development - RootzWiki
Im downloading v3 right now. Dirty flash is just wipe cache and dalvik cache then flash right? Its been a long time man lol. I normally do a full wipe.
Thanks and cheers!
Yessir that is it and yes you are correct on the dirty flash method =)
Thanks just dirty flashed. Rebooted, stuck at Google logo lol!!! Guess my phone went weird some place. Craziness!
Check your md5's as a few people are getting mismatches and incomplete dnld's
