Any reports on battery life or deep sleep on 3.3? I'm still on 2.5 but my battery has been so much better I'm a little hesitant. Getting 94-95% deep sleep when not using it.
Also is chrome the only browser now?
Ok, I just did a complete wipe and clean install of JB 3.3. First thing I did was to download Titianum Backup and run it. When I did, I got this message:
"WARNING: This device's Android ID has changed". Then is shows my current ID and my old ID and says "This normally happens after a device replacement or factory reset. The Android ID is the most common way for apps to identify the device. Any app that relies on it for security/licensing purposes may stop working (or need to be reconfigured) unless you restore the previous Android ID now.
I have flashed and did factory resets a bunch of times and never seen this before. It gave me the option to restore my old ID and I did. Any clues why this happened?
After every wipe Titanium does that. Very useful imo
Samething happened to me. I just clicked the "switch to Old ID" and everything seems to be OK.
I can't get google now to work right and I think I'm not getting my emails to push. I don't know what could be wrong. My signal indicator is greyed out, it says I have 4G but its grey. I'm pretty sure it used to be blue.
You can use widgetsoid, extended controls or power controls from the market I believe they are all free and allow you to put toggles in your noti pull-down if you'd like to try it.
UPDATE: Also seems I can't download from Google play on my computer and have it pushed to my phone.
Do I need to wipe the system? And yeah I see what you mean about the redundancies. The factory reset wipes the data and cache at once.
On rootz, the instructions say to run "Fix Permissions." Is anyone doing this?
No. And I've always wiped data/cache/dalvik back to back prior to loading the ROM. Even if its redundant, its never let me down in years of flashing.
Are you using TWRP or CWMR?
