CopperWires
Recent calls? Mine works better than ever as well.
IBT, I'm following pretty much every single mind-numbing post in Rootz. I have no indication that Jake is feverishly working on 3.5, although I suspect that he is. Not sure what else he could do to it: it's a nearly perfect stock ROM as it is.
I am sorry, saddened and slightly shocked that fellow Androiders here are having so many problems flashing Jelly Belly. My one issue was easily resolved by clearing the app data. Tether works, wifi works... everything just works.
Unless 3.5 has some really tangible improvements, I will likely stay right here for awhile.
Of course, that's what I said about 3.3 after I got it running right... and look how long THAT lasted
Nope mine works faster than it ever has before smooth as silk and never stutters
*sigh* has anyone been able to get Google Movies to work? Read recently that they allowed rooted streaming and many report that to be true. I keep getting "couldn't fetch license (error -1)" and to make matters worse it was after I bought 4 movies >.<
Wait what's this. No 3.5 release for my birthday? Gosh.
Happy Birthday Trooper!
jmar
mine is working ok
did you try clearing data or cache in the app settings or undoing the updates and reupdate?
Negatory. Voice working fine here. Unless, are you talking about setting it up as voicemail? Because that I have not tried and can neither confirm or deny...but calls and messages working fine
One thing that I need to get used to is the voice output when I'm using maps. One thing I have noticed is that it waits till you're almost to the point where you need to turn and then it tells you. Since I done this out in the country and I knew the turn was coming up, but how does this work in a city setting? The older version would start telling me at quarter a mile away that my turn was coming up. Guess I'll check this again tomorrow when I take a trip to another town.
How is everybody's keyboard working? When I was on 2.5, the word prediction was working really well and the autocorrect picked up most of my mistakes. On 3.4, the word prediction is slowly starting to learn my typing style, but 2.5 seemed to know it right away. Also, this keyboard isn't autocorrecting at all. If I type a word wrong, I have to click one of the words to the left or right of the suggestion bar. For example, if I type "dont" and then hit spacebar, it will insert "dont". it gives "don't" as an option to click and insert, but hitting spacebar inserts the incorrect spelling. On 2.5 (and every other Android ROM, version, and phone) it corrects basic misspellings by hitting spacebar.
I've gone through all the keyboard settings (there are a lot and are sort of convoluted). I've turned all all autocorrect settings, cranked it up to very aggressive, done everything I can think of in the settings. The weird thing is that I have all my keyboard settings exactly how they were on 2.5 and it was working perfectly...
EDIT: I cleared data from the keyboard and the autocorrect is working again. I'll have to wait and see how fast the word prediction learns me. I think that's a really cool feature.
3 known and repeated bugs for me:
1. Can't change the amount of time after screen turns off that face unlock takes effect. It stays at 5 seconds regardless of what I choose.
2. Can't get owner info to stick. I'll type of in, but whenever I go back, it goes back to blank.
3. Google search FC's when I try to interact with the results. For example, I search for "convert 5 kilometers to miles." The results pop right up and gives me the option to adjust the number of miles or kilometers. But as soon as I touch either the miles or kilometers, it FC's.
#1 works perfectly for me as well. You coming from clean wipe?
Always! You should know that jb, we're OCD brothers!
Hope your birthday was great Trooper....
3.4 is working great! I did a dirty wipe from 3.3...but I already had the JB Boot loader, and it appears that something was fixed since all of my inverted apps work perfectly. Have not had a single bug or issue at all!! Made my nandroid....this is definitely a Daily Driver build for me!!
Wow. Jellybean notifications changed so much that now notifications can always persist on top (meaning without updating themselves). Now Power Controls is exactly like AOKP toggles because they're always on top.
