I am really diligent wiper, I've actually never dirty flashed anything. One thing I'm new to though is format\system, data,and cache. Do you format all 3 of these?
3 known and repeated bugs for me:
1. Can't change the amount of time after screen turns off that face unlock takes effect. It stays at 5 seconds regardless of what I choose.
2. Can't get owner info to stick. I'll type of in, but whenever I go back, it goes back to blank.
3. Google search FC's when I try to interact with the results. For example, I search for "convert 5 kilometers to miles." The results pop right up and gives me the option to adjust the number of miles or kilometers. But as soon as I touch either the miles or kilometers, it FC's.
JB...not sure if you want to add this.link to the OP, but these are the Inverted GAPPS that I am using.
I am currently using the Phonsky, Calendar, Gmail and MMS and I am on 3.4. They all work fine on my Nexy, but no guarantees on everyone else's...so make sure you have a nandroid or can flash back to 3.4 and Gapps.
I download to sdcard/download, reboot into recovery, wipe dalvik, flash all of the mods I want to add, wipe dalvik and reboot system. They are all finally working again for me!!!
Also: Please remember that Jakeday says to make sure you wipe Dalvik before AND after you install any mods....not sure if that is still applicable since he said it back when he was doing the ports, but I still do it, and they are working perfectly for me!!!
http://rootzwiki.com/topic/29460-inverted-inverted-g-apps-update-7-5-new-playstore-ver-3713-and-mms-app/page__p__794637__hl__+inverted%20+gmail#entry794637
Good luck!!
How do I clean wipe? Sorry to ask such a basic question but I want to make sure that I do not miss anything as so many seem to be having issues when they don't get it right. Someone mentioned doing it from cwm but I don't see a choice for that.
NS, did you Fix Permissions in recovery?
No. I saw that JD mentioned it in the first post, but I heard some people saying over here that it may not have been required. What menu is that under in CWM?
EDIT: DO NOT WIPE ALL USER DATA! That also wipes your SD card/ internal memory, which is where your ROM is sitting, waiting to be flashed. You do that and you suddenly have a very nice (but expensive) paperweight!
It's not a total paperweight, but there is only one option to save the phone. One would have to flash a stock image through fastboot like I had to do yesterday. And it sucks.
I know, there is a final option to attempt a restore. But it's a rather tricky bit, especially for new guys.
I wasn't trying to scare anyone away from ROMming with it; ROMming has way more benefits than risks! And it is ALMOST impossible to truly brick a Nexus. But I would much prefer to avoid that whole scenario, hence the warning.
ClockworkMod Recovery (CWM) is a very useful, but very powerful, tool in the ROMming process. And like any powerful tools, it must be used with confidence and respect.
My 0.02![]()
Ah spit. I'm hesitant to post things I haven't flashed and checked out. But just for you, I replaced the old 1% circle battery mad with the Fast Soft Keys/Circle Battery mod for 3.4![]()
Am I the only one using TWRP still? Sounds like all the new users went back to CWM.
EDIT EDIT: Basic questions are good! A lot of newbie lurkers are reading this and want to jump in without joining the conversation. We wish they would join in, but I will never NOT answer a question because it's "beneath" me. Nothing is too basic. We would rather you ask and get this right than not and end up messing something up.
Chief,
You using the wilyjay mod, blue zenyth, that is in your dropbox? What all does it mod? Do you like it?
Alright. 3.4 installed and running. My first question was GOING TO BE - why didn't my apps from the play store auto-download as they always do?
Now my first question is why doesn't my Play Store work? It DID work. It reported an available update for Google +, which I installed. I also looked through the settings of the play store to see if I could get the auto-download to work. I didn't change anything.
I went to work for an hour and decided to look at the play store again. The icon is still there but when I click on it, it says, "App isn't installed". I opened the app drawer and sure enough, it is gone. Gmail is there and it works. Calendar is there and it works.
I reinstalled the Gapps for jellybean from CWM. Same result.
Any suggestions?
