andoird213
Android Expert
Can someone please check if purchased movies in Play Movies work for them? It doesn't for me
I'd like to know if it's a problem on my end
I'd like to know if it's a problem on my endFollow along with the video below to see how to install our site as a web app on your home screen.
May sound silly, but how do I know if the bootloader updated? I flashed the file from your dropbox Chief, but is there a way I can tell it worked for sure? Or just the fact that it flashed and it booted, means it worked?
It worked Dad
I really don't know how to check it... it's one of those "faith" things for me
EDIT: Stand by - beta testing in progress for 3.5!
I will add it today and thank you. I'm always hesitant to add mods that I don't try or use but you gave such a good explicative post on it I think its a worthy mod that many would want. Appreciate your feedback Ryan![]()
Per Jake: "3.5 is mostly cleanup of issues that were in 3.4, if you didn't notice any issues, don't upgrade lol"
one issue I've run into:
i had only been running 4g, so decided to run Wi-Fi
if I'm on Wi-Fi and the screen shuts off and i leave it for a bit when i turn it back on Wi-Fi either takes a bit too come back on or doesn't at all and i have to toggle it back on
any fixes for this?
Have you tried to install these? I'm not having any luck with the gmail install. I must be doing something wrong. The thread says to install it just like any other apk but it fails due to another app with the same name being installed. I'm guessing the original gmail.
What should I do?
No I like my apps non-inverted or regular. I haven't read the post Ryan linked been working all day
I'll check it out tonight, but often installing apk and them not working is incorrect permissions.
Am I the only one using TWRP still? Sounds like all the new users went back to CWM.
Fix permissions?
i flashed gapps when i flashed 3.4
Have to flash after each install, even a reflash
Are you using the 7-13 gapps? Try this: wipe cache/dalvik, flash gapps 7-13, then in "Advanced" Fix Permissions. Reboot.
There is no reason why Play would not be installed.
If THAT doesn't work, I might suggest flashing the 7-12 gapps.
