jbdan
Extreme Android User
Also, just saw that I have the storage folder with the sdcard0 in it. How did you guys fix that? I wonder if this is some of my issues
I would leave that alone. Or ask Iowa/ IBT as I saw him talking about it the other day
Need a mirror for 3.5. Dont use irc on my phone.
Where are the DL's?? It's not on his OP.
j/kWon't be for a while. Consider this the "soak test"![]()
As soon as I get both moved to my Dropbox, I'll link it
For $20 a downloadj/k
Apparently MMS/wifi is fixed in 3.5. I don't have an issue :/
Found my first issue with 3.4. The screen brightness toggle doesn't work and auto brightness is broken, won't even let meselect auto brightness in the settings. Anyone else?
Reboot your phone. Mine did that momentarily.
Man, been away for a few days, I'm still on 3.1, just downloaded 3.5 and will do a clean wipe and install as my backup just finished.
Is the volume louder?![]()
Thank gosh the MMS is supposed to be fixed! Gonna flash now
Fixed for me . WiFi and MMS working
EDIT: Sdcard0 is a Google thing, baked into Jelly Bean. We'll just have to deal with it.
Same here!! Woohoo! MMS! Now only if I could get Play Movies working![]()
Sorry to hear about that Patriot. I don't use that or I would check for you.
*sigh*
