CopperWires
Everything seems to be ok.
How do I get the weather card back on Google Now after swiping it away?
It will just reappear give it some time.Everything seems to be ok.
Clean flashed this one after a TIBU and a twrp backup...plus the inverted apps..works wonderfully. Everything back up and running in about 15 min!!
You got guts!Clean flashed this one after a TIBU and a twrp backup...plus the inverted apps..works wonderfully. Everything back up and running in about 15 min!!
I just restore data for Google search via TiBu. I don't know that it auto restores...at least didn't for me in earlier builds.
lol wut!?I went ahead and clean flashed. It just didn't feel as snappy as it should. Now it's much better. I tried to treat deep sleep and wound up with an unused toner in it. Has anyone else tested deep sleep?
If I'm not mistaken (because I might be and often am), GNow and the info you've fed it via searches and settings is web history based. Ever since v1.6 I've never restored any data with TiBu even for my apps. GNow works like it did on each previous build on every new flash clean or dirty. The cards are just there and appear without me doing anything but pressing the "OK" button when first entering it.
No problems here Chief ;-)Mirrors, Mods & Fixes:
[ROM] Jelly Belly v3.5 - 07/14/2012 - [JellyBean] [4.1.1] [Pure AOSP] - It's all about speed! - [VZW] Galaxy Nexus Development - RootzWiki - Page 1048
Post 10475
Anyone here having any problems? No?
EDIT: Hey there, that "Enhanced" Power Menu mod borked my phone! I press the power button and the phone hot re-boots every time. Gotta do a battery pull to get into recovery and flash 3.5... and NO "Enhanced" power menu! I replaced it with a 3.4 Power Reboot Menu mod that Jake says works. We'll see: flashing it now.
EDIT EDIT: Back up and running on 3.5, gapps 7-14, willjay's mod and the power menu mod. Everything SEEMS to be working smoothly. Will test out Navigation Lady on the way to Church.
See ya later with that report!![]()
ryan, are you flashing or installing the inverted apps?
You got guts!
Just read through his thread and even he says to not flash these and wait for JB builds, although he states the ones not to flash. So you're using Phonsky, Calendar, Gmail and MMS with zero issues you say? Props to you for going for it
As soon as TravP updates to the JB versions I'll OP it!
Post 10475
Did you flash gapps? Did you do a Titanium restore?Anyone having a problem with the signal bars not turning blue on 3g? When I switch from WiFi to 3g, the signal bars refuse to turn blue unless I reboot my phone. They will turn blue if I'm on 4g tho. I'm running v3.5 btw
I can't sorry I don't use the app or watch movies.Can anyone confirm or deny if Google Play Movies works on their device?
What exactly are you looking for just a color change?I read somewhere on this thread that you can color the soft keys blue. Now that I am on 3.5 I am ready to customize my daily driver. Can someone point me to a link. Thanks
It works for me on everything audio that plays through my phone. Earpiece, ear buds, ext speaker etc..Have you opened it and enabled it?I'm new to dspmanager. Is it supposed to affect all audio output? It doesn't work with Pandora for me.
