UBRocked
VZW Nexus Please!!!
here you go!
http://androidforums.com/verizon-ga...screen-1280-x-720-3-4-12-a-2.html#post4662694
screenshots in following posts
Cool thanks. I don't know that I'm down for this...but I'll may give it a whirl.
here you go!
here you go!
Just curious, what is this?
Sorry if this has been asked in this thread so far (don't have enough time to go through it all), but do any JB ROMs so far support fast USB charge yet? It's the only feature keeping me from leaving liquid 1.5 now.
TIA![]()
Are there any disadvantages to running lean kernel?
TIA![]()
Not sure. But I'm willing to bet that once you experience Jelly Bean, you won't want to go back to ICS just for fast charge! No doubt if it's not available yet, it will be soon. Someone else will have to talk to this subject, as I don't use it.
I found no disadvantages to Lean, but frankly, I found no advantages either. The stock Linaro kernel runs just as well, just as fast, and battery life is equivalent. Try it... if you don't like it, reflash the ROM and gapps and you're back to the stock kernel![]()
Great answer! Now where is this Lean Tweaks thing of which you speak?
I noticed that my phone had unused frequency slots up to 1650MHz, and no idea how to activate the things. I suppose that would help greatly!
Google search FC's when I try to interact with the results. For example, I search for "convert 5 kilometers to miles." The results pop right up and gives me the option to adjust the number of miles or kilometers. But as soon as I touch either the miles or kilometers, it FC's.
Clean flashed 3.5 + 7/14 GApps and still having this issue. Any ideas? It's bugging me...
It FCs on me too.
Cheif, I can enter numbers too but when I try to use the arrows to adjust the numbers it will FC. Try that on yours.
Edit: I did a clean flash 3.4 to 3.5, fixed permissions, and I'm not running any mods tweaks.
It FCs on me too.
It FCs on me too.
I have no idea: I just did the exact same thing - 5 miles to kilometers - and it lets me enter numbers all day long.
After flashing gapps, did you fix permissions before rebooting? And (hopefully) did NOT flash mods or kernels in the same recovery session?
It FCs on me too.
Yeah, that force closed it.
Okay, so I know what NOT to do!![]()
FC for me too, fine when just entering a number
NVM it fc on me too when trying to adjust the number wit the arrows.
Maybe this is something so few people use (I know I wouldn't have unless this came up) that it's just not listed as a known bug yet. Might be worth mentioning, or not idk, to JD
I know I haven't been around for too long, but is there some rule against posting on Sunday night? This thread is completely dead.
