PhilosoRaptor
sorry for the delay!
i tried it on the experimental kernel and it didn't work either
so i decided to go into franco's kernel app and try it out and it worked fine
so i suggest buying his app (it has a bunch of other helpful features as well and works for franco and lean)
then go to settings and enable fast charge
This worked, thanks! Funny that Leantweaks didn't work, but another devs apps that makes other kernels works! Hah, but I also didn't know that his updater app includes Imoseyon/Leankernal options too. That's a nice plus, I didn't even have to switch kernels (stayed on Lean 4.1.0) and it enabled fast charge without issue
It seems like the kernel versions showing up in the app are old though. Says the latest stable for Imoseyon is 3.10.0 and he's on 4.1.0 now, hah.
