jmar
Nexican
MMS while connected to wifi?
No problem. Just sent one from home on wifi
Tried chrome to Phone on 3.5 and didn't work.
No problem. Just sent one from home on wifi![]()
This is from Jakeday...he found the error in the Wifi settings in the ROM. Fix is coming soon, but for now:
This is a different bug than was fixed previously. A workaround until I get a fox in place is to use googles name servers for your WiFi DNS. Just connect to the WiFi, for to settings, WiFi, long press on WiFi network, edit, advanced options, change to static instead of dhcp and put in 8.8.4.4 and 8.8.8.8 for DNS2
It's not a deal breaker...but it would be nice to send texts from home with out toggling.If you find JB 3.9 there is no need to flash it. You get rick rolled on the boot animation. I guess it is a joke by Jake.
NOW it's live! Flash away!
EDIT: I moved it to my dropbox but it's taking forever to sync. Will post the link once it does
EDIT EDIT: Apparently it's there...
https://www.dropbox.com/sh/7i3haj0ibhzb66i/TucjL5wXZh
Check the MD5s!![]()
Is anyone else seeing that the stock clock app will not turn to landscape mode? I just started using my phone as a bedside clock and now it's not working.
What's "SuperWipe" in your drop box
It's a script that will do all the necessary wipes before flashing the rom and gapps.
Still an issue for me. Congrats on the flawless ROM!
So I tried this and it still doesn't work for me.It's not a deal breaker...but it would be nice to send texts from home with out toggling.
Atrain, are you on wifi? Wifi MMS is a known issue. Try turning off wifi and sending it over 3G/4G.
Also, if you'd like to try a different JB rom, XenonHD works with WIFI and MMSThanks, Chief. Turned off WiFi and my pic sent.
getting the wifi toggle boot animation loop after coming to work today and turning wifi on
tried fix permissions, clearing cache and dalvik
next is reflashing 3.8 dirty to see if that fixes before reverting
was working fine on 3.5, dirty flashed to 3.8 and it was fine yesterday, but not now
i don't really get it
Okay, I.m in.
I installed 3.8 and what a mess it was at first. I had to go back to stock twice, but i finally got it going.
The only complaint that I have is it likes to eat the battery more than ICS.![]()
Welcome to Jelly Bean! Check your Google Now & location settings. Those things love to constantly poll and kill battery. My Google Now is minimal and my battery life is pretty good![]()
Also, if you'd like to try a different JB rom, XenonHD works with WIFI and MMS![]()
