jbdan
Extreme Android User
Also Natemz is working on a theme chooser for the Jelly Belly rom. Looking forward to that!
Really already? That is awesome looking forward to theme chooser for sure
Nothing wrong with trying new venues! The whole "fixing permissions" and the need to by everyone! had me thinking something just isn't right so I had to try something else. Jelly Belly is still a great JB rom imo, but it'll be there if you want to returnHey it's been real, folks... but the Chief needs more customization options in his ROM than Jelly Belly's stock is giving me.
Based on jbdan's recommendation, I shall join Team Xenon and give that ROM a test drive around the block.
Have fun!![]()
Have fun!![]()
3.9beta1 working great for me....plus all 5 mods.3.9 is in beta now...being tested and hopefully a full build later today, will update and upload when I can. From early reactions this may be a great build...flashing now....
Has anyone ever told you that you're a bad influence Chief?
if anyone else is brave enough, the 3.9beta is in my dropbox
Edit and update: Beta2 being downloaded now....
According to Jakeday, the dev, he is building the extra, last bug-fixes into this build, before completely redeveloping the entire ROM for the 4.XXXX series, coming soon!!
No-Go on 3.9Beta2....boot-a-loopin....did not upload to my dropbox.
Beta1 is great, I am back there now. Hopefully we will see a full build tonight, however, Jakeday is on vacation - And limited to a dial up connection to upload the ROM, so we will see what happens!
Happy Flashing...soon!
Dial-up eek! Are you in the woods again![]()
Now running 3.9
Some apps won't update. Error code 491 and 492
Google search FC's when I try to interact with the results. For example, I search for "convert 5 kilometers to miles." The results pop right up and gives me the option to adjust the number of miles or kilometers. But as soon as I touch either the miles or kilometers, it FC's.
This is the best battery life I have ever had since I got this phone...on 3.9 with stock kernel. Even with GPS on all day I am usually at about 20-30% by 4pm...today I am at 63% with 2hr42min screen on time....cool!!!
What kernel are you guys using?
