I've been using lean. Do you have a link for Franco?
Yup on stock kernel...I think I did so much flashing in the last couple of weeks, I never gave the phone a chance to settle....
I am finally at 11% for the day...4hr28min39sec of screen on time...??? Wow!!
Stock battery?
Yeah that is awesome. And I'm assuming all on WIFI, never-the-less, still AWESOME!![]()
Yes stock battery...and nope most of that was on 4g...I just wish I knew what the difference was, except letting it settle.
For whatever reason, I am getting all green 4g signal now at work...maybe something changed with the towers near me?? I was on WiFi for only 4 hours...and the rest was 4g.
Also, for those that don't know, as much as I loved AOKP, with this kinda battery life, plus the notification toggles app....I am extremely happy with JellyBelly 3.9!!
That is insane on 4g I'd be hard pressed to ever leave that setup![]()
It's enough for me to give it a shot. I'm on AOKP and doing well but I'd definitely like to do better.
What is necessary for me to go from AOKP to Jelly Belly? I run NOVA Launcher and don't want to lose all of my settings. I also don't want to lose my camera pictures or Handcent history. Everything else can go.
I'll do a nandroid but what kind of wipe do I need to do to install this ROM?
I would: backup nova in its settings. Get the app SMS backup free and back up your SMS msgs. Then wipe data, cache partition, format system under mounts and storage, then wipe dalvik cache under advanced. This is with CWM if that is the recovery you are using. That should cover you![]()
OK...so I flashed the rom and it seems to be working properly.
Couple questions...
Is there a way to automatically download all of the apps saved in the Play store? I hate doing it individually.
Also, where are the notification toggles in this Rom?
Finally, is there any way to change the lockscreen? I'd like a 4-way slider so I can go directly to camera, gmail and handcent.
Thank you so much for all of your help!
Couple questions...
Okay so something funky today...
Flashed 3.9.1 last night...everything was golden...today, after about 5 hrs off charger I noticed I was at 74% battery...not a good sign. Checked the battery screen...and today the Phone Idle is more than my screen on time...??? Something weird going on with that. Reverted to 3.9. Will check again later tonight....anyone else??
