so my ndc is more open then? correct?
so i can just flash the kernel, and apn patch if need? like dkp?
i am also guessing the ndc is boot loader free of knox, never remember seeing it in odin mode
why would i need too? plus it comes ndc now, all new boxed phones will be ndc for vm
Yes I am one of those that flashed an older modem and bricked.Was an expensive mistake but got to learn some where.
How can we know what type of bootloader we have?
triband? can i check with out taking apart my phone? i have otterbox on, and keeping the screen clean while you put it on cant be an pain, making sure its dust free then i put it together i have my box still.
i see sph-l710avb
Yeah, Mahdi 2.9 is the best ROM I have tried so far. My battery lasts for ever. I highly recommend it.
you misunderstood my question i know my baseband, tri band
Mirror enabler has worked with every aosp and cm ROM I have tried, on liquid smooth it would only work if I didn't do the force close fix. Just make sure you reinstall it every time you flash a new ROM, I have had problems running it from a backupI decided to add an app to the list called MirrorEnabler. It actually works on all rooted Android smartphones/tablets. What it does is allow you to mirror your entire display to your TV through your Chromecast if you have one. KitKat has built-in Chromecast support so you don't need the Chromecast app in order to cast content using Netflix, Play Music, Hulu Plus, etc. KitKat also comes with built-in mirroring capability as well. For some reason, we're not able to mirror with the AOSP ROMs in this list. Using the MirrorEnabler app, you'll be able to mirror your display to your TV through the Chromecast.
Yes you can mirror games, you mirror your whole screen. There is some lag, the stock Roms seem to have the least lag. Try without the fc fix first, and if it doesn't work, use the fc fix. Sometimes it will also take an additional reboot to work alsoI have Chromecast. Will this enable games and such to be mirrored to the TV? If so, this will be awesome!
It's been awhile since I last checked on full mirroring with Chromecast. Only a few devises were supported at that time though. Unfortunately the S3 was not among those listed. I have been able to mirror YouTube and Netflix with the built-in Chromecast feature. I also have AllCast which I was able to play personal movies from my phone but most of the time they would lag. It's been awhile since I've used it too. Koush was still working the bugs out.
In my opinion, I think Localcast works better than Allcast. At least, I've had less problems casting local content using Localcast. I've barely had any lag using Localcast.
And yes, you can mirror games and everything else on your phone through Chromecast using MirrorEnabler. There's also a way to connect a PS3 controller to your smartphone/tablet using the Sixaxis Controller app. In that sense, I think your phone becomes better than the Nexus Player. Especially since the Nexus Player only has 8GB of storage.
Side note, you do have to reinstall the MirrorEnabler app after every ROM install. I use Titanium Backup to backup/restore my apps. I wipe the data for MirrorEnabler after it's restored and open the app to follow the process to get it working. After doing that, you'll be able to mirror again. I just wanted to add this app because KitKat is supposed to be able to mirror natively but we can't for some reason.
