1st off, thanks for your continued help. Unfortunately I still have a few questions.
In the Mirror Enabler thread there is a note for Samsung devices. It says "to enable Chromecast mirroring on a TouchWiz ROM, follow the guide below:
(For Samsung Devices ONLY!)
Go to system/etc/wdfconfig.xml
Find the following lines:*
1*(Change this 1 to a 0 and reboot)
WDF_HDCP_2_1
6789
0
0
Did any of you have to do this?
EDIT:
Never mind. This was not needed. As a matter of fact, I didn't have to change any of the file text.
Also, i didnt see an actual link for the FC fix.
EDIT...... Never mind. I was just setting the app up and saw the FC fix in the options.
Last question....for now. Hah. I read a good bit about disabling option 2 because it can cause issues. Has anyone here had luck with option 2 enabled. I read where i can go in and manually change the files to fix the audio.
EDIT :
I had to enable option 2 (force close fix) in order for the mirroring to work. The sound worked great too. So for those of you with questions about the Force close fix (option 2) , you may end up having to enable all 3 options like I did.
:thumbup:
I usually don't need to ask so many questions when applying a mod. Lord knows I've flash a ton of them. It's just that there is no actual step by step tutorial. Sure would be nice if there was one for the S3.
EDIT:
After reading back through quite a few pages of the main mod thread, I was able to find more than enough information. It's not listed step by step but there's enough info between the posts to get a good understanding of what needs to be done.
EDIT :
Just remember to keep in mind that what works for one S3 may not work for another. The Mirror Enabler works so just keep trying. You'll find the combination that works for your phone.
Thanks again for the help guys. I appreciate your help and time.
EDIT!!!!!!!!
HOLY FREAKING MOLY!!!!! Had to enable all 3 options but I finally got the CAST option in Chromecast and I'm wireless mirroring anything on my phone to my television . I'm in shock right now!!! OK, time to play with this thing and see what all I can do with it. When playing a games I experienced a little lag once in a blue moon. Definitely nothing major at all. Chromecast has an option you can adjust that helps with lag. Mine was so slight that it didn't even affect my game play. SWEET!!!!!
A HUGE THANKS GOES OUT TO ALL OF YOU WHO HAVE CONTRIBUTED TO THIS THREAD AND AN EXTRA SPECIAL THANK YOU TO AB5TRACKTION FOR SHARING THE INFORMATION HERE. YOU ROCK BRO!!! :thumbup::thumbup:
:thumbup::thumbup:
