Does Bliss have Dynamic Color Changer? Man, been having issues waking up device on DU and AICP. Plus on AICP bringing up recents takes years at times.
Upvote
0
Trouble waking your device sounds like a kernel issue. Either that or you've got a ton of apps trying to run at startup.
1) Are you running the default kernel or another?
2)Have you messed with the performance section and turned the MIN setting down below 384000?
3) Have you tried to undervolt? DON'T! Wait and see how the phone acts before attempting to undervolt.
4) Have you adjusted any of the kernel settings ( governor, i/o, or TCP congestion control, etc)?
I can tell you this with certainty. The stock Bliss kernel will work fine. Be careful if you start messing with the kernel settings. That can destroy device performance if set improperly.
Also, the newest d2lte DKP kernel works great. I've ran both it and the default kernel and had success with both.
Here is a link for the 4.4.4 DKP kernels only. 4.4.4 BUILDS ONLY!
Index of /decimalman/dkp/dkp for AOSP 4.4.x
If you decide to try Bliss, leave the kernel settings alone for a couple days and see how it acts on your phone. Check performance and battery usage.
After you've ran the stock kernel and decide you want to try DKP. 1ST make a nandroid backup so you can restore the default kernel if for some reason you don't like DKP. Always keep in mind that some phones can be finicky when it comes to kernels and kernels adjustments. Kernel settings that run perfect on my device may not work as well with yours.
If you have any questions regarding kernel set up, ask. People can tell you what works for them. That doesn't necessarily mean they'll work for you but they may.
I have some bad news for Dirty Unicorns fans. Dirty Unicorns once again dropped support for d2lte. Well, there really hasn't been an official build since August but we did get unofficial builds from various developers. Since DU dropped d2lte again, there might not be anymore unofficial builds.
Thanks. Yes, think it might be kernel related. All I did was the norm for me, flash BMS kernel. I never mess with kernel settings. I'll do a clean install later and see if it fixes it.
I hope it gets you straightened out. I'm sure you'll like Bliss too. The OmniSwitch will get a force close pop up once in awhile but it starts right back up on its own. I'm talking maybe a second. . I wouldn't even consider it minor. Overall, Bliss is solid as a rock. The options available even surprised me. LOL! :thumbup:
Didn't get around to flashing it til this morning. Oh yes very impressed on the features.
On a side note, I'm looking to pick it back up to hopefully come up with a 5.0 release. So DU 9?
Just had a random reboot on bliss.I was using ohub campfire app.I've never had trouble with that app on any other ROM.Could of been a phone fart who knows,thought I'd share.
I've read that some users experience a random reboot occasionally. Personally, I've never had one. It could be a corrupt download or a few other things. I would download a fresh copy of the ROM and start fresh.
If you're using Titanium Backup, make a backup now.
I would then download a fresh copy of the ROM. I would also use the newest version of the PA Modular Mini GAPPS. Some people have had GAPPS issues. I've never had a problem with the PA Modular Mini package.
This is the PA GAPPS thread link. Just read down the list and try the package I mentioned.
http://androidforums.com/showthread.php?p=6478223
I use Philz and choose the new ROM install option then wipe cache and dalvik cache, flash Bliss, back up to the 1st recovery screen, scroll down to power options and select reboot recovery, then flash the GAPPS package. I set up the ROM and let it sit for several minutes. I'll then sign onto Play. If it takes longer that 2 minutes for Play to load, reboot the phone. It'll boot back up and then you'll have to access to Play. I download Titanium Backup and restore my apps MINUS DATA.
Sorry for the long post but this is the way I flash Bliss and it runs great for me. I hope it does the same for you.
I do it the same way.Must of been a phone fart hasn't happened anymore.
Just had me another random reboot doing nothing.Just a heads up. I had my 1st freeze up and had to do a battery pull. I was using the default camera and had taken about 5 or 6 photos in a row. The screen went black and that was a wrap. I gave it a minute or so to see if it would come back on but it didn't. Couldn't even hold the power button down and get it to reboot. I pulled the battery and it's been running fine for the past 8 hours.
Just wanted to add that I'm running the DKP kernel too. I doubt very seriously it had anything to do with it.
I wanted to give you a heads up in case it happens to you while using the default camera. :thumbup:
Just found out that Cyanogenmod is going to deunify the d2 builds for the Galaxy S3 after unifying them in February. There's already an unofficial CM12 d2att build out there. I don't know if this means that all other ROMs will be deunifying d2 builds also. Looks like from now on, at least with Cyanogenmod, have to look for d2spr builds once again.
Deunify? Are you serious? WTH? Lets hope others don't do the same.
If they do we'll just have to start removing the asserts from the d2spr builds again.
Do you have any idea why they decided to Deunify?
Don't know. Just found out that they'll be deunifying d2 builds. Could be just because it's an older device and they feel the support isn't there. Could be they're having problems with commits for unified builds with Android 5.0.
Right. If it is because of 5.0, possibly they'll unify again once they've had more time to work with it.
It's really no biggie removing the asserts from the Sprint builds. The unified builds just made things a little easier.
I actually made a video and written tutorial posted in my ROM, Mod , etc thread in the Boost section back before they unified the builds. I'm glad I left all that info up. Newcomers may end up needing it to get their Boost and VM phones to run the d2spr builds.
I've been told if Knox is installed there's no way to flash ROMsThis is the ROM DU is based on. Doesn't have as many features as DU though. But you can use Xposed Installer with GravityBox [KK] to add a ton of features to the ROM. And GravityBox [KK] was just upgraded to be compatible with 4.4.3.
I will say this, Omni Rom is actually smoother and more stable than Dirty Unicorns. But that's probably to be expected since there are less features. I have not had one force reboot yet.
