10/02/2013
- New install procedure (see OP)
- Switched from Superuser to SuperSU
- Themed app launcher icons for Phone, Contacts, Music Player, and Downloads
- Removed Virgin Mobile MobileID app
- Stock Touchwiz messaging app now displays as "Touchwiz MMS" in launcher to better distinguish it from 8sms
Ok, so I didn't move the files for Release 2 to another server yet. How about we try Release 3 instead?
This is a single flashable ZIP, no need for restoring backups pre-install. It works by placing a tar archive of my working /system on the /data partition (temporarily) then decompressing it back to /system. Tar files preserve permissions and ownership so when it gets extracted, everything works as expected. I may eventually switch this over to a two-file installer, one part flashable zip, one part tar system image. The script can be modified to extract the file to the /data partition, the internal sdcard (/data/media), the external sdcard (/storage/extSdCard) or just about any partition with enough space. Due to the way it's currently set up, you MUST have approximately 800MB of free space on your internal storage. This still uses VaeVictus, I want to eventually switch over to an Aroma-based installer and give the option to use either stock kernel or VaeVictus (and
xstefen's kernel when it's ready) but that's a project for a later date.
Bug reports/logcats welcome.
Future updates will come as smaller patches, flashable zip only as they will likely just replace individual files. Enough changes may warrant a complete re-release of the 'full' base but probably not because the updates will be cumulative.
Release 3 currently resides at Android File Host. I know a lot of you have graciously offered me some hosting space and I'll be happy to use it. If the offers are still on the table, please PM me. I know I have gotten back to some of you already, but I may have missed others.
