dibblebill
Android Expert
If using 2.4.3.0, when you open the Wipe/Format menu, IF I recall correctly, you should be able to select your various partitions. A factory wipe can achieve the same effect.
Newb here, how do you "wipe data" as directed in the OP? Is that the command Format Data in Team Win?
I flash the ROM without wiping data and it seemed to work just fine.
Probably because this is based directly off the stock ROM. I usually like to do a full wipe, just in case of any discrepancies.
I'm highly regretting wiping data now, as I realize that my Titanium schedules were only backing up my data, rather than the apps. Also, the Play Store has some issues with app downloads.
Edit: I'm currently having loads of issues with the ROM. Until they're fixed I'm flashing back to stock.
I'm on victorious. Should I restore to stock MG5?
I flashed and had "signature verification failed". Did I do something wrong?
Tried again without signature verification and got stuck with the blooming colors for 10 minutes. Gave up and restored.
Please tell me exactly what steps you took to install, what recovery and version of recovery you are using and what ROM you are coming from.
Coming from Victorius, TWRP 2.4.3, wiped cache, wiped dalvik, wiped system, install zip. Wipe cache and dalvik. Reboot.
I actually installed this on my Sprint phone (just to play with it). I did a full backup then format in TWRP then flashed, then wiped everything except extSD and system. Got stuck at Google bootloader. Flashed again and didn't wipe anything, bingo. Looks beautiful except the fact that I can only get 3G/no LTE (expected)
Just got done with the install and it seems cool. I just think its weird that I'm still getting the Victorious boot animation. everything else works fine though
The victorious splash screen is part of the kernel. When you flashed, did you wipe everything, nothing or partial? What version of recovery are you on?
I would really like that if you dont mind. My big computer is in shop, all I have right now is an Acer aspire and the screen is so small it cuts off the start button on odin and I can't click it.If you need a flashable zip for TWRP 2.6.3.0, let me know and I'll upload the one I have.
