TheBritton
Resident Galaxy Cat
Factory reset under settings works. I had to return mine. Left TWRP recovery on there though. Lol.
Yep! I do have the stock recovery linked in the library of this Guide if ya decide to throw it back on there
No root method via app? Like Minstro or poor?
how do i put tht on my sd card do i connect it to my cpu
You can put your sdcard in a USB adapter if you have one, otherwise you can transfer it over the USB cable while the sdcard is in the phone.
this doesnt give me a download link (You can find Odin here: Rwilco12's Android Repository) what do i do
AN I THANK YU FA ALL YA HELPWhen flashing Busybox and Superuser I get following message (after it checks for MD5 file and doesn't find one and then does...)
Verifying zip signature...
Verifying update package...
[I think this is where the problem starts]
E:signature verification failed
Error flashing zip '/external_sd/busybox_v1.20.2
Updating partition details...
When flashing Superuser it also says
E: failed to verify whole-file signature
Any help?
Any help?
A wipe seems to be all it needed. I am now rooted!!! You ROCK!
enjoy!!!Is this process the same on the Virgin Mobile Galaxy Victory as it is on the Sprint version?
Every time I try to transfer the SuperSU and Busybox zip files to my SD card a error pops up saying that the disk files cant be read. Do I need these zip files? Should I unzip them?
