Just noticed somewhere along the way i have lost the ability to screenshot? any suggestions? maybe its a timing issue sure would be nice if our favorite rom guy (wink wink) would add a screen shot button to power off options. lol
Gotta be the timing, or something else interfering. I just tested, and it works fine with the new kernel.
Should I have wiped dalvik and cache after flashing test kernal but before rebooting? I forgot and just rebooted. No problems or anything, just wondering. And should I do it now or for it to be helpful did it need to be done before reboot after flashing?
I always wipe davlik when flashing anything but that's just me
Okay, I located the calendar widget "com.sec.widgetapp.SPlannerAppWidget.apk" but can't seem to get it working as a system app (or at all for that matter). I set the permissions and everything. Gtalk is working just fine though.
I fixed my mms issue by flashing the stock vmobile rom (I'm pretty sure my issue was that my phone didn't come with the right rom, as I never had a vmobile splash screen when I got it). Decided to fresh format and repartition my SDcard while I activated, then updated everything.
Rooted then installed Victorious, setup the script for link2sd as mentioned above... got it working but it's time for bed. I'm getting a bit tired and forgot to note the permissions on the script files, can someone check for me (if it matters- perfectionist-), I think the trick to making sure it works with least effort is to setup the script, install link2sd and then reboot without running link2sd. I accidently ran it, and it seems to have broken the external2internal part... even tho I went back and tried to replace the scripts again. Looks like I may be starting this part over tomorrow...lol
The calendar widget I think isn't matching up with the current calendar that is being used by victorious. Thats my theory since the naming convention is different than the default app. Correct me if I'm worng.
I've read that the victory's that MMS doesn't work (partially set up for sprint it seems) can run twrp 2.5 and 2.6. Even after you flash stock and fix your MMS. I had one and exchanged it because there was no fix or stock ROM to flash at that point. But it seems they have a few latent sprint benefits.
I was looking through the build.prop and noticed HDMI enabled said true, does anyone know if this phone is capable of HDMI out?
Edit: also no lag in keyboard -at all-, such as when holding down backspace. Was there w redspot.
