theadamguy
And I didn't even get into the whatsits, hownows and thingamabobbers.
-quoth dr. Seuss
so im new to rooting and all of this stuff, i rooted my phone last night for the first time and made it work as a hot spot and put on the VaeVictus kernal.
from what i understand, i should be able to also put Victorious on my phone now? but i see that victorious comes with vaevictus, so would i need to remove my current version? or just proceed with putting Victorious on my phone? thanks.
currently what ive done:
followed "rooting for newbies" guide
VaeVictus
WiFi tether TrevE-mod
well i did something wrong...my phone wont download/install anything....
not sure what to do now..
OK, I did all that, both partitions are primary. But the partitions are still not being found. It's like the system doesn't find the SD card.No, you place the Micro Sd Card into your computer using the adapter and format it using Partition Wizard.
OK, it's starting to make more sense, I think my partitions are flipped. I should make the EXT4 partition the big one, not the other way around. I'll try that and see if that's it.The main partition of your SD card should be the larger one. The second partition should be Ext2, Ext3 or Ext4 (Primary as well) and should not be much larger than 2Gb. Many will say that 2Gb is too large, but that's what I use. The Ext partition is what Link2Sd will use to link to apps.
The SD card with 1.83Gb is the Internal SD which I believe is that same on all Victory's.
I don't think the Ext partition shows up when looking at the Device memory.
Device memory
Total space: 20.22GB
SD Card
Total Space: 1.83GB
That's all the system reports. As far as i can see, either on the phone or on my PC when the phone is connected, I now have a 1.8GB SD card.
Am I misunderstanding something here?
Thanks for sticking with me!!
I think this may have been answered before, but what is the purpose of using both extSd2internalSd and Links2Sd? If you have swapped the internal and external SD cards, why would you need links2SD to copy apps to a second partition on the external SD? Wouldn't the files already be on the main partition?
With extsd2internalsd only the larger additional files that some apps have (usually games and some are over 2gb) go on the ext sd. The app itself still goes on internal.
So having both ext2intsd and links2sd gets the whole job done.
Link2sd moves things that cant be moved with ext2int...vic versa.
