Try rom toolbox in playstore. It has a buildprop editor. Twrp, with power off hold volume up and power. But rom toolbox also has a rebooter in it that lets you reboot into recovery from the app. I use it all the time. You can even add rebooter as a widget. When you first launch rom toolbox it will ask you what recovery you have, obviously choose TWRP.![]()
Does anyone have a apk file of the memo application? It's not a huge deal but I do enjoy the app more than third party ones.
Hey guys, new-ish (VM) Victory user here. I've got my phone rooted and flashed with the latest Victorious ROM and for the most part everything seems to work great. Except I've run into a couple issues I can't figure out (and they're probably related). The first is that I can't open MMS pictures. They appear on the thread view but tapping on them either does nothing or gives an error, depending on which program I try to open with (QuickPic or FX Image Viewer). The error from FX Image Viewer is "Unable to load image; the system denied access to read file."
The second issue is that in the camera app, tapping the button in the lower left corner to view the stored pictures does nothing.
My theory was that these issues were occurring because I uninstalled the stock Gallery app, so I figured installing another Gallery app (QuickPic) should take care them. But no. They persist.
If I have to reflash Victorious I will but I'm hoping there's an easier way. Any suggestions?
C|
https://app.box.com/s/6u5sr798ecn7l7drt9ah
Here is the stock gallery app.
And here is the odex file. https://app.box.com/s/qfqtcg2cj8ol535rna8h
Try just placing both the apk and odex file in system/app. Let it overwrite the existing ones. Use a root file explorer.
All system apps are in system/app.
The existing ones are not there, which is weird because the installer thinks they are. Anyway I tried copying the .apk to /system/app and no go. Also tried installing the zip through TWRP and still no go. Something is clearly borked because now when I try to exit the camera app the phone locks up.
I'm just going to reflash the ROM and NOT screw with the gallery app this time.
C|
Reflashed the ROM and the Gallery/Camera are working correctly again. All appears to be well now.
Note to self: Freeze apps first to make sure you can live without them.
C|
Thanks for this ROM and root. I just got a Victory from VM on Friday. Did the root in another thread (used TWRP 2.5.0), updated the baseband and then installed this rom. All went smooth except the TrevE tether app crashed the phone requiring a battery pull to recover. I uninstalled the app, downloaded the latest .apk (3.2-beta2-041713 **synergized**), and now that works.
What does not work, or rather what I need to understand better, is notifications.
When I get a voicemail I see it on the "swipe" screen, but if I swipe but do NOT check voice mail, the notification vanishes. Is there a way to change the behavior so that a voicemail notification remains until I actually check voice mail?
Also is there a way to put the .apk for visual voicemail back onto the phone?
I really like this ROM. Thanks for all the work and support.
It's in the kernel (boot.img)
You'd have to make changes and flash the new boot.img
Got it all installed and working great but how do I install themes? I find them all over Google but how do I know which ones are compatible and then how to install them
